Old 04-13-2008, 05:16 PM
delaplanemusic delaplanemusic is offline
Default Journaled or Extended...
Hey there. I have heard from several people that it is better to format your external drives to Mac OS Extended if you are a Pro Tools user, but have also found some information online recommending using Mac OS Extended (Journaled). Does anyone have any info on what format works the best with Pro Tools?
Thanks,
Nick
Old 04-13-2008, 05:35 PM
TCDet TCDet is offline
Default Re: Journaled or Extended...
Mac OS Extended (Journaled) (All Drives)
Pt's 7 and up. OS 10.4x
Old 04-13-2008, 05:43 PM
Andre Knecht Andre Knecht is offline
You’d be better off if you’d get in the habit of consulting your equipment’s documentation first, and save the “take a poll ’round the internets” for when the former isn’t clear. It’s also faster, especially when you consider that all PT documentation is readily available as a downloadable set of pdf docs. (Never mind that it gets installed with the application.) Last but not least, these pdf docs are fully searcheable, making their use an efficient snap.
That said, page 71 of your “HD Getting Started Guide” goes like this:
Formatting Mac Audio Drives
(Mac Only)
For optimum performance, audio drives should
be formatted as Mac OS Extended (Journaled).
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 04-13-2008, 08:10 PM
Howardk Howardk is offline
Thanks,
Nick
You did not specify your OS X version, or ProTools version/platform. Pretty tough to get advice without providing basic information. Extended was right a few OS and ProTools versions back, now it is Journaled. As Andre suggests, it is all in the manual for your particular version of ProTools/OS. . .
...for system configuration info see my profile
(Click on member name)
Old 04-13-2008, 11:29 PM
blackmacdaddy blackmacdaddy is offline
Also
NOT case sensitive NOT
For Pro Tools to run correctly.
Just trying to help, Best
Walt
It's only R'n'R but I like it.
Old 04-14-2008, 01:35 AM
Also:
If you are on an Intel:
Do not format your audio drives with the GUID partition table!
You will encounter problems when running such drives on PPCs. PT on PPC has problems with these drives. Some session won´t even open when you have audio referenced to GUID formatted drives.
Always use the Apple partition table. You only need GUID for boot partitions on Intel macs.
I hope they will fix that soon or at least put up a big sign in the manual or the web-site.
frank.
HD journaled or no? Floydio Post - Surround - Video 2 11-12-2009 10:12 AM
journaled or not journaled?? lukeyy Pro Tools TDM Systems (Mac) 1 01-14-2006 08:59 AM
EXTENDED Vs JOURNALED HD FORMATS Dual Mackie Storage Subsystems 3 02-25-2005 04:41 PM
Mac OsX Extended Journaled Problem Luis Miguel Storage Subsystems 4 11-03-2004 07:21 AM
Format Extended or Extended Journaled for PT6.2.3? AAR Pro Tools TDM Systems (Mac) 3 02-06-2004 07:46 AM
