Waves Plugin Issue - Help...
Really appreciate any help or problem solving here. I have emailed waves support but hoping someone here might have some advice.
All my plugins to date are V9 Waves plugins amongst a few other branded plugins. Protools 2020.3.0 Windows 10 Pro Today I purchased Waves H-Reverb and installed it however the license for this is V11 so used the proper waves central installer to install it instead of using the Offline installer for all my old V9 plugs I have licenses for. Install went fine. Went to open Protools and use H-Reverb. Issue arose where I can see the Waves plugin shell but nothing more. Please see photo attached. I have re-scanned plugins and also gone into the right folder to remove the InstalledAAXPLugin file and re-launch PT's. Same issue. Any help would be much appreciated. |
Re: Waves Plugin Issue - Help...
You can run V11, V10 and V9 simultaneously, but Legacy software can only be installed using Offline Installers
Login to Waves Central, click on Offline Installer (LH column) See at bottom of page: Create an Offline Installer Install from an Offline Installer
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
Thanks. Yes all my V9 plugins were installed via the offline installer and work fine in ProTools. It is the new plugin I purchased today that is a V11 plugin that im having the issues with.
It installed fine, no issues, however upon re-opening Protools and trying to use this new plugin, the waves plugin skin opens without any of the plugins functionality. Hopefully the image I uploaded shows what is appearing when I try to use this plugin... |
Can you see both 9.92 and 11.0 WaveShells in
C:\Program Files\Common Files\Avid\Audio\Plug-Ins Or in: C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Waves (please see attached image)
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! Last edited by unkJE; 07-04-2021 at 09:59 PM. |
Waited quite a while for you to reply ...
This is our one fine day between lots of rain & I must get back up on the roof while the weather permits .. (my problem/not yours!) Will check back later today Your pic's too small for me to see how you're routing your Stereo Aux Track Can you use H-Reverb on an Audio Track, or do you get the same result? Did you register, install & activate H-Reverb as described here: https://www.sweetwater.com/sweetcare...aves-software/ If so, try re-installing H-Reverb Good luck!
Call Waves, they have (mostly) excellent tech support.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Hi - yes both waveshells are in the plugins folder.
Yes installed the plugin via the Waves Central app. It is registered. Plugin wont work when i try use it as an insert on a track and also via audiosuite on raw audio files... very strange.
Waves plugin Keyboard issue? | Cryos | Pro Tools 10 | 3 | 03-12-2013 12:11 AM |
New Waves plugin | albee1952 | General Discussion | 13 | 06-12-2011 11:18 AM |
Another annoying issue. A good issue, but still annoying. Plugin latency. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 05-20-2010 05:26 AM |
waves ssl plugin | Greene | Pro Tools TDM Systems (Mac) | 25 | 03-21-2006 10:59 AM |
Waves L3 / Best plugin I have ever used | dwdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-22-2004 09:27 AM |
