PT9 stress test?
OK so I know I'm going against the grain but I have assembled an AMD 6-core machine with 8GB RAM and I've cross-graded to protools 9 and I want to see if this beast works. Can anyone recommend a proper stress test? I found this in one of the stickies:
Re: PT9 stress test?
This really is the only "benchmark" for PT that I know of. Which processor do you have? I have the 955 and have been looking at upgrading. How many Dverbs can you get?
I ran dverb2 last night using the PT9 D-Verb. 254.
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
Thanks Mike, is that with one of the AMD 6 cores or your i7?
On my i7.
Mike.
Right now it's going quite badly. I'm not sure where the glitch is but something is badly wrong. I suspect it may have something to do with me using non-avid hardware, namely the Tascam US-1800.
For some strange reason, just opening a protools stress test project (not even pressing play or record) sends my CPU blasting to 80% usage on all 6 cores. WTF? I'm going to check out the system tips for optimization but i'm off to a bad start with this hardware setup. Any hints about where to go for some good coaching would be much appreciated. |
C2D E7400 @ 64 = 71 @ 90% system Usage 2.5 Ghz
C2D E7400 @ 1024 = 84 @ 90% Sytem usage 2.5 GHz Athlon II X4 620 @ 64 = 76 95% system usage 106 watts Athlon II X4 620 @ 1024 98 95% System usage Phenom X6 1055 @64 = 113 90% Sytem usage 2.6 GHz 142 watts Phenom X6 1055 @1024 = 144 90% Sytem usage 2.6 GHz Phenom X6 1055 @64 = 118 90% Sytem usage 2.8 GHz Phenom X6 1055 @1024 = 147 90% Sytem usage 2.8 GHz Phenom X6 1055 @1024 = 157 90% Sytem usage 2.8 GHz DDR2 1066 These were some tests I ran about a year ago when I built a AMD rig to see how the 99.00 X4 620 would compare to the 99.00 Intel Core 2 Duo chip. I would have thought the X4 620 would have done a little bit better being as PT heavily favors multi threading. So I upgraded to the (199.00?) X6 and saw a huge performance increase. This was with Windows XP SP3 and whatever version (8.0.1cs2?) of PT that last worked with the original MBox. With XP and PTLE 8 the X6 AMD ran smooth as glass. This was with a Gigabyte MA785GN-US2H which is a mATX board with integrated graphics. White I dont have any specific advice to offer I would start with the General Troubleshooting sticky and do the Avid recommended optimizations. Chances are its a simple configuration issue.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Thanks sunburst. I'm headed to Protools 9 Technical FAQ - Solutions to common probolems now. If you know a better thread, I would appreciate knowing about it. So far, this is very disappointing. So psyched for Protools 9 and my Awesome X6 (which is something like 3.3 to 3.7 GHz) and yet it won't do diddly. NOTE: I am using a TASCAM US-1800 as hardware. Might it have something to do with that.
Remember, I'm getting all 6 cores zooming top 80% usage when i merely open a file. |
You have anyone you could borrow a Digi interface from long enough to optimize and trouble shoot? That would eliminate the variable of the Tascam. The X6 on XP was great here so I feel that you have a good chance of getting this going. It's getting late here and I have an early day tomorrow. You might try downloading the DPC latency checker and see what it says. http://www.thesycon.de/deu/latency_check.shtml Also CPUz and SiSoft Sandra Free will come in handy. Last but not least you might want to note the settings and then break the overclock temporarily. I doubt its the problem but its another set of variables to eliminate.
THANKS for the useful feedback.
I'm not overclocking. It's the stock clock speed. I do in fact have a Digi 002 available but the firewire card is fried and it's got the power supply problem. I expect to have it fixed (to the tune of $400) but would love to try and isolate something more specific before wasting my money. I'll probably drop it off for repair in the next day or so. |
Pro Tools 10 stress test results - DON'T believe the hype... | Steve Gates | macOS | 12 | 02-25-2012 01:52 PM |
A PT stress test? | Inthewoods | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-27-2010 06:32 AM |
Mac Pro 8-Core = 406 Mono Dverb inserts! My stress test. | MindDead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-27-2007 12:50 AM |
Another PTLE Stress Test- "DaVerb Bounce Test" | BioFeedback | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-11-2004 05:48 AM |
Best way to stress/test my 9600/G3 PT system with OS 9.1? | Boom Chic | Pro Tools TDM Systems (Mac) | 7 | 05-05-2002 12:38 AM |
