Old 11-02-2018, 06:37 AM
Moviesound Moviesound is offline
Default Why has insert (or pan) selection stopped following track selection?
Why has insert (or pan) selection stopped following track selection? I thought this used to work with the dock? But on 12.8.3 it's no longer working?
Old 11-06-2018, 10:06 AM
reichman's Avatar
reichman reichman is offline
Default Re: Why has insert (or pan) selection stopped following track selection?
Both pans and inserts are following track selection over here. Maybe you have a pref turned off somewhere.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 11-07-2018, 01:22 AM
Are you on 12.8.3? I can't see any preference that controls this and feel like I've tried everything. Definitely used to work
Old 11-07-2018, 05:33 PM
reichman's Avatar
Sorry Moviesound, I couldn't easily figure out what might be turned off on your end. I'm on 2018.10.0 and EuControl 18.3.0.244.
Track select on S3 switches insert or pan on Dock as one would expect.
Nathaniel Reichman
Move the selection forward by the selection amount not working in PT10 [SOLVED] Captain Audio Pro Tools 10 3 06-17-2014 10:43 AM
Play/Edit Marker stopped following the timeline selection stern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2007 11:50 PM
Selection Clears when Playback is Stopped tikboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2006 09:25 PM
Selection goes away when playback is stopped Produce_Dept Pro Tools TDM Systems (Mac) 3 03-12-2006 07:10 PM
Losing selection when stopped Jeff Jewett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-10-2002 06:13 PM
