Old 09-30-2005, 09:04 AM
djrobbie djrobbie is offline
Default High pitch whine/buzz
hello to all mbox users...i love my mbox and ptools however i'm have an issue.
i'm using both systems a mac with osx and a clone pc. i'm having the same
high pitch whine/buzz coming throught my mbox....
the high pitch whine is slightly less on my mac...
What should i do?
1) buy a power conditioner to deal with the dirty power in my house?
2)buy a new pc with the digidesign specs? (my current pc is a clone and may not be up to
digidesigns specs)
3) buy a new mbox and hope that the problem goes away?
please
help
dj robbie
Old 09-30-2005, 09:54 AM
SoundWrangler SoundWrangler is offline
Default Re: High pitch whine/buzz
This comes up often... kinda sounds like LTC timecode, right, but in the analog outs only; doesn't end up in your bounced files? The Mbox is incredibly finicky about using only its own factory-supplied USB cable (with that cylindrical ferrite choke); so your problem could be caused by:
1. Using any other USB cable to connect the Mbox, no matter how "good."
2. Using a USB extension cable, even with the orig. factory cable.
3. Using a USB hub between the CPU and the Mbox.
4. Your factory cable is bad; in which case only Digi can provide a replacement.
p.s. does anybody know yet how the Mbox 2 is reacting to non-factory USB cables - same issue?
High Pitch Whine After Pro Tools 7.0 Loads concretecowboy71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 03-21-2009 05:58 PM
Mbox 2 high pitch whine Doner005 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-14-2009 09:55 AM
High Pitch Whine SOLVED cal1875 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-05-2008 09:58 AM
High Pitch Whine MacBook Pro/Mbox crash4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-23-2007 07:30 AM
High pitch whine or noise when recording Isabelle Pro Tools TDM Systems (Mac) 12 02-06-2004 06:41 AM
