Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-02-2020, 03:33 PM
ejinbc ejinbc is offline
Default Folder Feature Requests
this thead has been made sticky. follow instructions here, please
Has anyone found a way to expand a given Folder's view in the Mix Window but not in the Edit Window ? I was really hoping the views would be independent. I read through the manual and did not see it referenced. Any shortcuts ?
This would be useful, for example, to collapse all Aux channels in the Edit Window and but keep the Aux faders visible in the Mix Window.
Stay Safe
ejinbc
Old 04-02-2020, 03:42 PM
ZEUSS ZEUSS is offline
Default Re: Independent View of Folders in Mix and Edit Windows
I JUST posted about this.... Doesn't seem possible...
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3
Macbook Pro, 2019 (15,1) Mac OS 12.7.2 Monterey,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3, Apollo 8 Silver,TwinX.
Old 04-05-2020, 01:22 PM
Nope, there is apparently no way to do this (yet). After playing with folders a bit more, I also really wish they had implemented automatic routing when you drag a track into a routing folder (expected this) - would be a great workflow for quick grouping functionality.
As there really is only one new feature in 2020.3 (plus bug fixes), I wonder if the MODS should make a 'sticky' for Folder feature requests.
(1) Independent Folder expansion views in Edit and Mix Windows
(2) Automatic routing (ctrl+drag) when moving tracks
(3) ??
Stay Safe
Old 04-05-2020, 03:43 PM
SDDP SDDP is offline
OUCH!
that's annoying, so in Mix you have either regular or narrow. Maybe add this so idea scale?
Wish we could have a mix of narrow and regular in the MIX window at least
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
Old 04-05-2020, 05:38 PM
Originally Posted by SDDP View Post
OUCH!
No. It means that if you have the folders all open and spilled out in the edit window, they will all be open and spilled out in the Mix window. You can't have them closed in the edit window taking up less real estate and then have them Open in the mix window at the same time when you need to do a quick mix adjustment. They are either always open or always closed.....
Old 04-05-2020, 07:03 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
(3) ??
Stay Safe
There is automatic routing from the new track dialouge box. Just tick the option.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 04-05-2020, 09:57 PM
LesB
"...when moving tracks."
Yes, when creating a folder selected tracks can be auto assigned, but moving existing tracks into a folder does not automatically set the routing. There should be an option key for this perhaps. How about ctrl drag and the track takes the folder as output path, ctrl+shift drag and the track takes the folder as output path, and then the folder uses the tracks's old output as the folders new output - or something like that.
E
Old 04-05-2020, 11:32 PM
Oggy Oggy is offline
Stay Safe
ejinbc
I’m trying the same thing with memory locations (with show/hide tracks) + window configurations. Works only when you have one display monitor and you have to switch between views.
I’m just learning how powerful memory locations are...
Old 04-06-2020, 02:15 AM
noiseboyuk noiseboyuk is offline
(3) ??
Stay Safe
Personally I don't want (1), I prefer them linked. No harm in a preference though, if that could be done.
(2) seems essential to me, alongside new tracks created within a folder (these apply to routing folders only of course). At the moment Folder Tracks are great, Routing Folders are a bust imo.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 04-06-2020, 04:01 AM
JFreak's Avatar
JFreak JFreak is offline
Okay, I'll bite. Avid may also be interested in how users feel about this and what could be improved. So from now on let the message format be like:
1) Folders currently work like this: explain.
2) I would like them to work like this: explain more.
Janne
Feature Requests janmuths General Discussion 3 07-18-2010 02:28 AM
Feature requests DamonMoritz Aspera DigiDelivery 1 05-03-2007 05:46 PM
Bugs, feature requests and tip requests! Basil Rush Pro Tools TDM Systems (Mac) 6 12-07-2005 08:21 AM
new feature requests! (again) mattm Pro Tools TDM Systems (Mac) 11 04-14-2002 09:30 AM
A few feature requests: uno1234 Pro Tools TDM Systems (Mac) 32 10-12-2001 01:28 AM
