Old 07-26-2001, 05:04 AM
jackruston jackruston is offline
Default OMS Reinstallation
Hi Guys
I need to reinstall OMS. Should I remove it from the system first (if so how?) or simply install over the top of it. I'm running 9.1 on a g4 400. Thanks
Jack
Old 07-26-2001, 07:25 AM
DigiTechSupt's Avatar
Default Re: OMS Reinstallation
I would suggest trashing the following before running the OMS installer:
From root level of the hard drive:
-Opcode folder
From the System Folder:
-OMS Folder
From System Folder>Extensions folder:
-Open Music System
-USB OMS MIDI Driver
From System Folder>Control Panels folder:
-OMS Preferred Device
Brent
Avid Audio Tech Support
Support FAQ
help with reinstallation up to 8.05 pt le muscmp macOS 6 01-31-2014 01:44 AM
reinstallation on new computer brainiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-04-2013 05:26 AM
reinstallation of pro tools LE 7 boots2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2009 05:14 AM
os x reinstallation -> vst problem dboles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-11-2008 07:21 AM
reinstallation problem jtll24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2006 10:31 PM
