Talkback issue
I've finally installed my D Command and all is well so far except for this issue.
I'm getting a weird sound when the talkback is engaged. The quality of the internal mic seems fine but mixed in with it is the sound of a movie projector, for lack of a better description. It does not go up or down with any level adjustments, it's always the same level. Anybody have this? |
UPDATE
Turns out it is the Internal mic. I did more tests and the external is fine. The"movie projector" noise is coming and going with the internal. Is this normal? Did I get a faulty unit?
Digi?? |
Re: UPDATE
So no one else is seeing this? I must have a faulty unit.
Re: UPDATE
the internal mic on mine is pretty unbearably loud... i've switched to using the external...
Re: UPDATE
Comparing the quality of the internal Talkback on my D-Command to my D-Control, the D-Command's talk is extremely noisy. The D-Control's talkback is clean as a whistle.
Don't know if this is an inherent problem with D-Command or if my D-Command's Talkback is just throwing a hissy-fit. All my regular clients notice the quality difference immediately.
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo; |
Re: UPDATE
Do you mean D Control? They're both ICONs. I'm just using an external mic and it sounds good but it it is disappointing that a brad new unit would have this defect.
Source Talkback AAX gets auto talkback | MIKEROPHONICS | Post - Surround - Video | 0 | 11-20-2013 08:15 AM |
D Command drag clip talkback issue | kptkarl | Post - Surround - Video | 0 | 07-24-2012 02:16 PM |
Please fix the Talkback | Touchwood Studios | ICON & C|24 | 2 | 11-23-2009 11:17 AM |
Talkback help! | javi79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-19-2009 11:30 AM |
Talkback mic | sights | ICON & C|24 | 1 | 07-20-2007 09:48 PM |
