Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-18-2020, 04:08 AM
Kinsman Kinsman is offline
Default EZ Drummer2
Hi all-
PT 2020 on Windows 10.
I've downloaded EZ Drummer 2 (trial) and on its own that seems to work as it should. But.
It does not show up in my audio suite>plugins list; and when I drag a clip from EZD into my PT timeline, it plays but sounds like someone playing drums on a piano. I've created audio, instrument and midi tracks and the result is the same.
How do I:
"Register" it as a plugin with PT, or
Simply drag tracks to PT?
Old 09-18-2020, 06:03 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: EZ Drummer2
Originally Posted by Kinsman View Post
Hi all-
How do I:
First always a good idea to keep your complete system list in you signature line (see mine below) . That makes answering diagnostic and help questions straight forward and efficient .
Second EZ drummer should show up in both your real time and audio suite sections under (Instruments) (hint IMO best to select to have PT show plugins as both "Category" and "Manufacture"
PT may simply not have scanned EZD as a new plugin.
Try closing PT. trashing your PT preferences, and then launch PT again and see if EZD shows in plugins.
Not sure what you mean by dragging a "clip from EZD to PT timeline" ? If EZD is not showing in plugins do you mean you launch it standalone ? Give some detail exactly what you are doing and how you are dragging from EZD and what you are "dragging" (audio or midi file ?) into exactly what kind of track in PT ?
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 09-18-2020, 07:40 AM
Thank you.
Yes, I open EZD as standalone. Create a pattern and put it in the lower box then drag from there over to the timeline.
I have shut down PT...I'll try again after work, and provide more detail.
Old 09-19-2020, 06:41 AM
K Roche's Avatar
Thank you.
I don't use or know about Easy Drummer specifically so I don't know what "Put it in the lower box means".
Regardless I suggest :
Before you launch PT again, trash the preferences first. That will/should trigger a rescan of plugins and hopefully cause PT to scan and Load EZD which should solve your problem.
I don't use EZD or Windows so I cant be more specific
System :
Enjoy the Journey
.... Kev...
Old 09-19-2020, 11:02 AM
bradch00 bradch00 is offline
EZD2 doesn't show up as an audiosuite plug in, insert in on a stereo instrument track. Dragging and dropping the MIDI from standalone to a track that doesn't have EZD2 inserted on it will render interesting results. Uploaded graphic as to what I meant.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 09-19-2020, 06:02 PM
Some things to consider:
1-(in case you are on Pro Tools First)only 3rd party plugins that are gotten from the Avid store work with PT First(as far as I am informed). I'm not sure of where you got your demo version.
2-Virtual Instrument plugins(like EZDrummer2) are not designed to be used in AudioSuite. They are designed to be used "live" as an insert(usually on a STEREO INSTRUMENT track). Midi note on the piano roll trigger the sounds in the plugin.
3-midi notes can be placed in a few ways, including:
A-drag the midi loops from the plugin's library and drop on the INSTRUMENT track(be in GRID mode so the loops will snap to bars).
B-drop midi notes on the piano roll with the mouse.
C-record midi notes with a midi keyboard or trigger pad device
Old 09-20-2020, 09:46 AM
Thanks very much for the screenshot. I saw immediately what you had explained; it seems to be working properly now, at least the quick thing I just did.
Thanks for the help. Now to continue writing.
Alesis E Kit, Pro Tools & EZ Drummer2 - Help! philrollett The Drum Room 1 02-16-2017 08:23 AM
Problems with EZ Drummer2 kt90 Virtual Instruments 19 05-27-2014 05:22 AM
pro tools le 8/superior drummer2.0 zory Virtual Instruments 1 09-30-2009 11:34 PM
