Old 10-19-2018, 12:35 PM
spock999 spock999 is offline
Default High Sound not as open after mixdown
I use a Print Track so when I Print I can just active/deactive the monitoring of this track to ear the sound before and after Print and I don`t know why but the High sounds are more open before the print ... why ?
I have no process on the Print track and only a SSL G BUS with a 3 db compression and Protool Maxime with a Peak at -1.3 and not compression on the Main Bus. If a Protool Guru could help I
Your eyes can deceive you don't trust them , Mix with your ears
Old 10-19-2018, 02:48 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: High Sound not as open after mixdown
I cant remember off hand which is which, but depending on what you are bouncing , printing and from where PT will automatically dither some and not others. Perhaps that is the case in what you are doing.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 10-19-2018, 03:05 PM
Thanks that a good clue
Old 10-22-2018, 04:46 AM
Dizzi45Z Dizzi45Z is offline
One serious bug that nobody seemed to care about (but ruined many of my mixes that I sent out and didn't realize) is the fact that Pro Tools will bounce differently then what you hear on playback if you ever have a mono-stereo plugin on a track that is inactive. For example, if you have a reverb aux that is mono, but then you use a mono-stereo plugin, then make it inactive and put a stereo plugin on after the inactive track. It will playback as expected, but it will bounce down very differently with anything related to that track. Maybe this is related to the differences you are seeing.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 10-22-2018, 09:30 AM
HEAT engaged on your print track (should be bypassed)? Any chance you're double busing something to the monitor output that doesn't mute when you listen only to your playback track?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
high pitched sound? xcracer41 macOS 1 02-16-2013 08:22 PM
Bob marley's high hat sound? janmuths The Drum Room 7 12-23-2012 05:12 AM
Best Sound / Mixdown Option akhafaji Windows 4 11-20-2011 12:10 AM
Mixdown - mixdown pitch shift problem kakeneeditoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-03-2007 03:38 PM
nasty metallic sound on mixdown problem Delusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-08-2003 11:21 AM
