PIA SSL strips & ducking
I thought I knew how to set up ducking with a compressor or channel strip using an external sidechain. But trying to setup the recently released SSL branded E & G channel strips put out by Plugin Alliance has me wondering: what am I doing wrong?
I create a mono send from the track I want to have duck the track with the strip on. I feed the strip's external sidechain with that send. Set the controls on the E or G like I would with any other strip or compressor. Except that when there's a signal on the sidchain instead of lowering the signal for the track the strip is on it raises the level. I figured out the switch settings I need to have the E or G respond to the sidechain (in the 'Dynamics to' section the DYN and Key buttons are pressed). The only way I could get what I wanted to have happen is to press the Norm/Inv button to show Inv. Is this the way it's supposed to work? And what other settings do I need to set - like Gate or Expand and which should it be? Just to confirm I knew what I was doing I substituted in the Waves SSL G Master Bus Comp (which I just got today through AD) and it worked like every other channel strip and compressor I have. Same for the Blue Cat Dynamics plugin - raise the level coming in on the external sidechain and the output of the plugin drops like it should. I've not worked with the hardware version of SSL so I'm flying blind that way. This is not just an exercise but I want to be able to duck the levels of certain tracks when other tracks need the focus a bit more. |
Re: PIA SSL strips & ducking
I tried YouTube and could find zero tutorials with either the original or the SSL branded E & G strips from Brainworx/Plugin Alliance that used the external sidechain. If anyone has a link or links to such I'd be forever thankful to you.
Seems to be working as expected here. Have you tried taking the Gate/Expander out of the equation? (Range and Threshold turned all the way down.)
T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
The manual could be a bit clearer on explaining things. All they say is to check out the presets that do ducking of which there is only one. And when that one is called up it's not set to use the external sidechain. |
Ducking aside - how do you like the plugin(s), Jack? I've just started demoing the E, and I'm digging it so far.
Can I ask you where you got presets for the SSL 4000E?
I can't find .tfx files for the SSL either on my system or on the PIA site. T
Click the box (librerian menu) in the plugin where it says "factory default".
I was wondering if maybe the installer put them in a location other than the default one (Documents>ProTools>Plug In Settings) Additionally I can't find any presets downloads on the PIA site anymore..? If I recall correctly they used to be under the Downloads header of a plug-in/product page. T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 Last edited by Muddy-T; 08-04-2018 at 12:09 PM. Reason: Punctuation |
I don't know if you've seen the massive thread over on GS or not but there seems to be a calibration mismatch between the meters. An issue I'm having (and this goes back to the original bx strips (E & G) is that from time to time on OSX when using the 'return' key for any operation like going back to the beginning of a PT session the state of switches and knobs changes. I submitted a tech support ticket and they've confirmed the problem. When a fix will come - who knows. It happened to the original bx E (which I have) and both of the SSL branded strips. |
Another route you could try is to get the PIA download manager and use that to reinstall everything. That will give you the latest revisions of any plugins you have from them. |
Ducking | NativeLuv17 | Tips & Tricks | 3 | 10-27-2008 04:47 PM |
Ducking within the console | timcorder | VENUE Live Sound Systems | 1 | 06-21-2008 02:35 AM |
Ducking | Eless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-24-2005 12:05 PM |
Ducking | strizzack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-07-2005 05:01 AM |
Ducking? | neil_mcdermott | Tips & Tricks | 9 | 07-11-2003 11:53 AM |
