Old 02-07-2013, 10:57 AM
Armando Armando is offline
Default How to route USB audio into Pro Tools
Hello, I just purchased a Roland TD-15KV V-Drum set.
The TD-15 module has the ability to send and receive both audio and midi by way of USB 2.0. It also came with a "driver" for the Mac OS which puts a TD-15 icon into System Preferences(mainly for changing buffer size).
Now, when setting the Input and Output in Sound Preferences, I can sellect the TD-15(as well as the "Play Sounds Thru..")
I'm running Pro Tools HD 7.4.2 via a Dual 2Ghz PPC G5 with 4 Accel PCI cards. The G5 has an optical lite-pipe out also.
The TD-15 also has 2-TRS outs but I'd like to see if it's possible to route the audio out via USB 2.0 into Pro Tools.
I've tried several approaches but so far, nothing
Any one??
Armando
Old 02-07-2013, 11:05 AM
Top Jimmy's Avatar
Default Re: How to route USB audio into Pro Tools
Originally Posted by Armando View Post
...I'd like to see if it's possible to route the audio out via USB 2.0 into Pro Tools.
Not with 7.4.2 it isn't.
James Cadwallader
Old 02-07-2013, 11:37 AM
Ok, then what's the earliest vs of PT that supports this?
Also, what about the "stand-alone" Digi Core Audio Manager? Any chance to do routing here?
Armando
Old 02-07-2013, 11:46 AM
Craig F Craig F is offline
With a TDM system is it imposable with any version
Thank you,
Craig
Old 02-07-2013, 01:32 PM
Very frustrating
Armando
Old 02-07-2013, 03:36 PM
limitations of old tech
Thank you,
Craig
Old 02-07-2013, 03:47 PM
albee1952 albee1952 is online now
I not positive but I'm not sure the Roland transmits audio via USB. Just run audio cables from the Roland brain to your interface.
My 2 cents only, but I wouldn't bother with audio from the Roland kit. Just connect midi(either midi cables or USB) and put up a stereo instrument track and insert any of the available drum VI plugins(Addictive Drums is the best bargain and can be had on sale for $99). (been doing this with a TD-10 kit for years and it rocks)
Old 06-12-2018, 01:25 PM
chrismeraz chrismeraz is offline
Is this still impossible?
I have an aD5 drum kit and I'd like to send USB audio to PT for recording.
Why? Because I'm getting a lot of hum through the audio cables, and wouldn't the quality be better anyway if I don't have to depend on the D/A converters in the aD5 drum module? It would also speed up set up and break down time.
So, is it possible?
The manual says this module will transmit audio through USB (as well as MIDI). But I couldn't find any further clues in the manual.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 06-12-2018, 07:43 PM
So, is it possible?
Still not going to work. If you were running a Mac, you might be able to create an "aggregate" of the kit plus your usual interface, but that's not an option for Windows users. If you are getting lots of hum, it probably a ground loop(something that is usually fixable). If the drum "brain" is not close by the interface, its probably plugged into an AC outlet that has a different ground path than the computer/interface. Running the analog outs of the drum module thru a stereo DI box might solve that
Need a bit of help getting Apogee 200 to route audio DrFord General Discussion 0 04-24-2010 11:28 PM
Why the audiosuite audio signal can-t route to a bus? sonuslab Pro Tools M-Powered (Win) 0 03-25-2008 01:26 AM
Route QT Player audio into PT via ReWire? Studio Dweller Pro Tools TDM Systems (Mac) 0 11-01-2005 09:47 AM
Can't route CPU audio thru I/O! mrdecibel Pro Tools TDM Systems (Mac) 2 05-28-2004 05:04 PM
The 'second hard drive for audio' route.... Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 07-21-2000 04:50 PM
