ProTools 12.6 "closing session"
Takes 10 minutes to close a session !! Can we start with this issue.
WHY would it take 10 minutes to close a session? And... any action I attempt gets me "pro tools not responding" I think this new laptop should be able to handle PT?? My desktop PC and desktop Mac work fine. New laptop Dell Inspiron Windows 10 12g ram 512g solid state drive 2.7ghz I even took new laptop back to Best Buy and they re-set everything... I am having nothing but problems with PT12.6 on this laptop. Cannot do any work AT ALL. Keep getting AAE 9173 message. "remove native plug-ins" AVID's support is non-existent without a fee. |
Re: ProTools 12.6 "closing session"
My first guess is that a plugin being used in your session is not playing nice with Pro Tools and your computer - probably also what's making it take so long to shut down. I'd start disabling or removing plugins to try to figure out which one is causing the problem.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
No plug-ins being used at all.
thanks |
Same issue here on a desktop PC, I stop the run by the task manager when PT 12.8.1 is closing ... else it stays in 'no response mode' but I never tried to waiting for 10 minutes !!!
Pro Tools 2024.3 - Cubase pro 113 64bits- Windows 10 pro 64bits - wavelab 12 pro - core i9 9900K - 32 Go RAM All SSD- interface : ANTELOPE ORION Synergy Core. Ideal-Sound Not_To_Flow |
I'm having this issue from time to time, too. Trashing prefs seems to fix it for a while - then it reappears on some other session a week or two later. I'm on 12.8.1, Windows 10 Pro (latest update), and I've had it for a few of the latest versions (don't recall when it started). The first fix I got working was based on advice from Avid support, where I would create a new session and Import Session Data from the problematic session. This worked, but since then the issue has re-surfaced with other sessions. (Happy to share details of this fix if anyone wants it.)
In my case it usually starts with a very slow opening of a session, and when launching performance monitor I see the overall CPU load hitting max (red) with all of my 8 cores pretty low otherwise. When I see that, I know I just have to kill PT, trash prefs, and reboot. Hope this gets sorted out soon. Trying to close the session would just be a waste of time - it can take 30 minutes. |
"Compiling" multiple sessions into one "Master" session. Any pointers? | Nollykin | Tips & Tricks | 17 | 12-09-2013 10:36 AM |
"Pro Tools not responding" error and a very "laggy" session! Help! | drumbumd | Pro Tools M-Powered (Win) | 0 | 02-10-2012 05:37 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
"closing a play or record file" in Task window | BillyT | Pro Tools TDM Systems (Mac) | 2 | 08-21-2009 01:45 PM |
protools "performs illegal operation" when opening session | nated | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-28-2002 06:20 PM |
