Old 06-21-2017, 05:31 PM
nuggynuggy nuggynuggy is offline
Default PT 12.7, Kontakt 5, iMac MIDI Studio, Launchkey 49: The whole thing just crapped out
Hi All,
First time poster... been searching these forums for DAYS before posting as I know there's generally an answer on here. I've tried everything in the posts I've found so, here's my issue and the screen shots associated with it.
A few days ago, was trying to get my Rickenbacker Kontakt 5 bass emulator playing through a template (Mixed by Marc Mozart) but for some reason neither Kontakt nor a normal MIDI Synth (Omnisphere) would pick up on the MIDI Controller (Launchkey49). I used it previously on non-template sessions and it seemed to work, but now it looks like I may have done something incorrect.
The Launchkey can control the knobs and faders on PT12.7 but the keys wont make a sound. Kontakt isn't picking up the midi in PT either but will work fine stand alone.
I'm lost. Any suggestions, a slap across the head or a good scolding would help.
Here are my screenshots.
If I solve this, I will post screenshots of how to do it next time
Old 06-21-2017, 09:17 PM
Default Re: PT 12.7, Kontakt 5, iMac MIDI Studio, Launchkey 49: The whole thing just crapped
I am also getting:
"Pro Tools is unable to communicate with HUI. Power-cycle HUI and check its connections. note, if HUI is not in use, update peripherals dialog to prevent further warnings"
My Launchkey is going directly into my Mac as there's no input in my Universal Audio device.
I've also checked through a MIDI Monitor which is picking up my controller but giving me these commands when used through PT12
File Type: jpg Screen Shot 2017-06-22 at 2.16.30 pm.jpg (50.5 KB, 0 views)
Old 06-21-2017, 09:18 PM
(better image)
File Type: jpg Screen Shot 2017-06-22 at 2.18.07 pm.jpg (64.7 KB, 0 views)
Old 06-22-2017, 08:07 AM
john1192 john1192 is offline
Originally Posted by nuggynuggy View Post
(better image)
hi, is your midi assignment on your instrument / midi track correct ?? did it lose connection with your Launchkey ??
you did not show any pics of your midi setup on the track(s) that will not play the keys .. you have first midi instrument so you do not need any Tracks Record enabled .. it should play whatever midi track you are working in / and highlighted
might need a little more info here to help ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-22-2017, 05:50 PM
Hey John, Thanks for responding.
Apparently I was WAY off. It had nothing to do with the above I had originally posted, and I was mixing up an audio track with an instrument track and messed up my signal routing. I was trying to run my MIDI instrument through an audio track which didn't work, I was then routing it incorrectly to the wrong track which made it a double idiot mistake.
I sure felt like a moron after that...
Thanks again for replying though.
Cheers
Old 06-22-2017, 06:44 PM
Cheers
all good !!! it is always a cable .. even if a virtual one !!!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-23-2017, 04:03 AM
Cheers
You're no idiot as you were able to figure it out which is a lot more than some do. I often find when I run into a weird problem to walk away from it for a while and something will come to mind to check out that I hadn't checked before - and that's usually the fix.
Jack
QAPLA!
How to Record Kontakt 5 Studio Drummer Cayce macOS 25 12-04-2017 04:52 PM
Cannot add Novation LaunchKey 49 MIDI keyboard to PT Ex axel76 Pro Tools Express on Windows 5 09-21-2014 09:45 PM
Interesting thing about 27" Imac nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-24-2009 09:09 PM
002 mixer crapped out ?? jvox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-25-2005 08:22 PM
One fader that has crapped out! Coll ProControl, Control|24, Command|8 1 09-12-2003 10:36 AM
