Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-16-2017, 02:50 PM
Fixius Fixius is offline
Default Zoom H6 Multitrack Interface w/ Pro Tools 12
Greetings. I'm using a Zoom H6 as an audio interface for Pro Tools 12, until I can afford an upgrade. It connects fine using the onboard "stereo mix," setting. However, it seems to not work if I set it as a "multitrack interface." I'm hoping to have the ability to record discrete channels into Protools, but it seems the only way to input from the Zoom is by the zoom outputting a stereo mix of the mics I have plugged into the Zoom. Despite setting channel 1 and 2 to different tracks, each track is inputing a mix of both channels. Is there a way to keep the channels separate? Am I missing something?
Thanks!
Old 06-17-2017, 10:15 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Zoom H6 Multitrack Interface w/ Pro Tools 12
You have to install the Multi-track driver if you are on Windows.
There are two drivers. One is for 2in/2out the Multi-Track driver is for 6in/2out.
Download the driver here for Windows.
https://www.zoom-na.com/products/fie...rder/downloads
On the Zoom H6, you need to choose Multi-track when you are setting it as an audio interface if you want discrete audio channels.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-17-2017, 05:31 PM
Thanks. I'm running Pro Tools 12.7 on Mac (Sierra). When selecting Multitrack Interface on the H6, the inputs aren't working.
Old 06-18-2017, 12:35 PM
Benoni's Avatar
Hmm... I'm on Windows and my Zoom H6 works as it should with Pro Tools.
Did you try defaulting the IO in Pro Tools?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Help Pro Tools 10 with Zoom H4n as Interface beto515 Pro Tools 10 2 10-22-2012 01:39 PM
Can i run more than one interface at once with PT9? (Mbox2 and Zoom H4n) bandagedhand Pro Tools 9 6 08-08-2012 06:37 PM
Eleven Rack As Multitrack Recording Interface? martind Eleven Rack 3 06-20-2011 01:44 PM
multitrack interface! tony.tipton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-13-2011 08:02 PM
Zoom H4 as USB Audio I/O Interface for Pro Tools? dogsbody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-21-2009 10:42 PM
