Old 06-12-2017, 02:52 PM
Fritz Fritz is offline
Default editing a multi song session regions to individual sessions
I have all the regions in each songs session disk allo folder.
But every session has the full length of the source regions.
Is there a way to hack off (and delete) "excess regions" so that I'm using less space?
I have all the source material saved in the master.
In other words, every session has 130MB regions, when each song needs perhaps 25MB of each region.
The sessions themselves just show me the parts of the regions I need, but I'd like to trim the rest.
Man I hope that makes sense .......
"Do not fear mistakes. There are none."
Miles Davis
Old 06-12-2017, 08:57 PM
Default Re: editing a multi song session regions to individual sessions
There are a few ways to do this(like most everything else in the digital world) Here's one way:
Enable the ALL group. Go into GRID mode. Find dead air between songs and hit B to Separate Clips(Regions on older PT). Highlight the clips for a song. Open the Clips bin(on the right) and Export Clips as Files. Retain the session settings for sample rate/Bit Depth and send them to a folder(before starting, make a folder for each single song). Leave the first song in place. Once you have exported the rest of the songs, delete all but the first song and re-save as that song title(or treat it just like the others and leave the original session complete).
Once you have a folder of audio for each song, create new blank sessions for each, use the Import Audio command to select and import all audio for each song/session.(since you know the tempos, set each session to the proper tempo before you import audio)
There are other methods, but this gives you the kind of instruction to figure out what you need to do, and you may discover something that works better for you
Old 06-13-2017, 04:28 AM
Thanks very, I'll give that ago.
Miles Davis
Old 06-15-2017, 01:29 PM
that worked well. thanks very.
Miles Davis
28track multi-song session...... otoby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-04-2009 11:45 PM
How to copy one song out of a multi song session? Kevin Mowry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-14-2007 11:36 AM
Multi-Song Session - How to Split into Separate? 100grit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-09-2005 03:32 PM
making individual songs out of a multi-song session sidereal Pro Tools TDM Systems (Mac) 3 11-22-2001 12:31 AM
merging regions from different SESSIONS to 1 SESSION? RP Montoya Tips & Tricks 1 04-08-2000 03:00 AM
