Old 01-06-2009, 01:37 PM
25ghosts 25ghosts is offline
Default 2 Minor Pro Tools 8 BUGS
Hi There,
I have found the following which I believe to be bugs
Both are of minor importance.
1) Take any audio recording (For ease of reproduction use region no longer than 3 seconds). Set PT to playback without looping. Now hit play. While in playback, start adjusting the volume fader and keep doing so until playback stops automatically, Keep the mouse button clicked all the time and dont stop adjusting once playback stops. You will notice that once the PB stops - so does the ability of moving the fader. Only work around is to let go of the mouse button and then push it again to regain control of the volume fader.
2) Master fader/bounce BUG
I wanted to bounce a snare drum which I had edited. I selected the region and hit play to ensure I was bouncing the correct audio. I decided to "normalize" using the gain on the Master Fader. EVERY time I adjusted the gain on the master fader it would NOT play the beginning transients of the snare drum. Thus, I had to hit play twice in order PT to play the file correctly. After EACH master fader adjustment I had to hit play twice to get PT to play the transient. First try would leave the snare short of it's attack.
Like I said, minor bugs - and PT 8 is running great here
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 01-06-2009, 02:48 PM
DigiTechSupt's Avatar
Default Re: 2 Minor Pro Tools 8 BUGS
I'll have these looked into!
Avid Audio Tech Support
Support FAQ
Old 01-06-2009, 05:13 PM
Thanks for the reply
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
Bugs in Pro Tools 9.0.3 mkosacek Windows 3 06-30-2011 03:43 AM
Annoying minor bugs garnoil Post - Surround - Video 7 02-18-2010 02:55 PM
Faced 2 minor bugs with PT 8.0cs3 today Alécio Costa Pro Tools TDM Systems (Mac) 6 08-20-2009 07:42 PM
Pro Tools LE 7.0 Bugs Larry Younkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-13-2005 11:55 AM
