Pro Tools LE 7.0 Bugs
I've come across two annoying bugs with PT LE 7.0:
1) PT doesn't always play when the space bar is pressed. I know this problem was reported in previous versions but it appears to have resurfaced. The problem seems to be highly correlated with the buffer settings. At low buffer settings (64 samples) it happens frequently. At high buffer settings (1024 samples) it never happens. There are no error messages, PT flashes the play button, the stop button and then halts. 2) Disappearing help files. I noticed during one session that the PT help files (Keyboard Shortcuts, Reference, etc.) are greyed out. I saved the session, closed it, and then re-opened it and the help files reappear. However, at some point during the session (I don't know when) the files are greyed out again. Strange. Anyone else observe these problems? AMD Athlon 64 3700+ ASUS A8V Deluxe 2 Gbyte Crucial RAM Windows XP w/ SP2 Pro Tools LE 7.0 Digidesign 002R |
Re: Pro Tools LE 7.0 Bugs
1) This was a problem I had up to v. 6.4 then it disappeared. In pt7 it´s back
/Dennis
Mac Pro 2.66 1gb Ram MacOS X 10.4.8 002R PT 7.3.1 |
The space bar problem happens at 1024 samples for me! I can clearly see both the play and stop buttons lighting, and I can see "play pause" paint at the bottom of the screen. Seems I recall somebody alluding that once Digi tech support acknowledged the problem, but classified it as a phantom, unrepeatable, inconsistent, uncorrectable issue. If I'm wrong on that I apologize. At best, it's still hearsay.
002R Win7, no PT GigaByte 970A-UD3/AMD FX(tm)-8120 8GB DIMM DDR3 AMD Radeon HD 6570 2 WDC WD10EURX-63FH1Y0 www.soundchasm.com |
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
Pro tools 11 Bugs | YKlein | Pro Tools 11 | 3 | 10-17-2013 08:36 AM |
Bugs in Pro Tools 9.0.3 | mkosacek | Windows | 3 | 06-30-2011 03:43 AM |
2 Minor Pro Tools 8 BUGS | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 01-06-2009 05:13 PM |
Pro Tools 7.3 bugs | mgoorevich | Pro Tools TDM Systems (Mac) | 10 | 01-02-2007 02:13 PM |
