Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 05-14-2013, 04:56 PM
abre abre is offline
Default Hard drive setup
What is the best way to setup my hard drives? I have a USB 7200 RPM drive with Komplete sample libraries. Two WD Caviar 500 gb HD, one as the system drive and the other as the recording drive. I have ordered a one TB 7200 seagate HD. Should that be the sample library drive?
Old 05-15-2013, 04:28 AM
Default Re: Hard drive setup
I'm confused - do you have 3 drives or 4? As I understand the 2 WD drives are internals right? That USB drive with the Komplete sample libraries - is that the one that comes from NI or what? If it is you don't want to use that as your drive for anything other than to install from it to whatever drives you want to use for your samples, etc. The Seagate you ordered - internal drive? If so yes you can use that as your samples drive provided it's not a 'green' drive that powers down or varies drive speed. 3 drives are good to have in a PT system - system drive, one for PT to record to, and a third for samples. I actually have three 2 terabyte drives - one each for system, PT recording and samples.
Old 05-15-2013, 06:21 AM
OK. Thanks. The external drive is not the Komplete 9 install drive.
Is this Hard Drive setup ok for PT? Georgerob General Discussion 7 10-25-2012 03:01 AM
How does everyone setup Hard drive? a2c macOS 40 03-09-2012 03:16 AM
Hard Drive Setup rfrance Pro Tools M-Powered (Win) 14 06-03-2010 08:33 AM
Which Hard Drive setup is better? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-07-2007 06:24 AM
Hard Drive Setup where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2002 12:41 AM
