Old 02-07-2007, 08:47 PM
univox1 univox1 is offline
Default tdm vs. rtas plugins
do tdm plug ins sound any better than rtas? is there a delay difference? is there an advantage with tdm?
mp
Old 02-08-2007, 09:27 AM
Default Re: tdm vs. rtas plugins
what about delay from plug ins? do they differ in thta way?
thanks mp
Old 02-08-2007, 06:05 PM
do rtas plugs have delays like tdm? that need delay comensation.
Old 02-08-2007, 10:49 PM
iamnerdyrocker iamnerdyrocker is offline
For the most part, any delay associated with RTAS plugs are absorbed in the Hardware Buffer Size. You will still see delay on most plugs that have a look ahead buffer in them (compressors like Smack! and Maxim for example).
If you hold Option and Command and click on the volume indicator of the mix window, it will switch first of all to show you audio peak level values, click once more and it will switch to 'delay' letting you see how much a track is delayed due to plugs or hardware inserts.
Keeping in mind, the delay does not account for external converters being fed from the digital outs, or for any delay or latency added from the outboard processor.
LE has no automatic delay compensation built it...it's called nudging tracks earlier in time and making notes in the comments window.
Old 02-24-2007, 02:18 AM
zodgilla zodgilla is offline
I'm still confused...I get it that PT TDM auto compensates for TDM plug-in delay but does PT TDM correct for RTAS plug-in delay or does one have to nudge the track as in LE?
Old 02-24-2007, 06:07 AM
Stig Eliassen's Avatar
ADC compensates for any latency, both RTAS and TDM.
Old 02-24-2007, 10:44 AM
Thank you! and ADC was introduced in PT 6.4...my head feels more clear already.
Old 02-24-2007, 08:39 PM
jre3132 jre3132 is offline
I agree...overall one doesn't really sound better than the other. HOWEVER, if you use Antares Auto Tune, the RTAS version tracks and corrects MUCH better than the TDM version.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 02-25-2007, 07:59 AM
JFreak's Avatar
JFreak JFreak is offline
No, only plugin connection delay is compensated for, not processing latency.
Janne
Old 02-25-2007, 05:59 PM
JFreak- So when using RTAS plugins, one must still check the amount of delay and then nudge the track accordingly? (if you can't tell, I'm new to TDM from LE so your answers are very appreciated - thank you!)
RAM for RTAS plugins Majorek Virtual Instruments 8 01-19-2010 07:05 AM
AU Plugins also run as RTAS!? nean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-11-2007 06:20 PM
PT Can't see my RTAS plugins? AudioArtCafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2004 10:55 AM
how many RTAS plugins can one run? outflowcrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2003 08:26 AM
What are the best RTAS plugins for LE? jazzsounds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-23-2003 02:28 PM
