Old 10-07-2019, 06:22 PM
jbreher jbreher is offline
Default Avid Pre calibration question
The readying gear for work saga continues...
I have a digidesign Pre. From my understanding, the Avid Pre is merely a cosmetic update of this unit.
AAR, the User Guide mentions the ability to calibrate each channel. It is however rather light on specifics.
There is an onboard oscillator. The manual states that this oscillator will -- after temperature stabilization -- output a 1.228Vrms sine wave out a balanced dedicated 1/4" TRS on the back panel.
There is also a means of feeding this oscillator to each channel (enable insert on associated channel when OSC is enabled).
Lastly, each channel has a Trim pot.
It is left as an exercise to the reader of the User Guide how to employ the above to actually perform a calibration.
My assumption: For standard cal procedure when all is working as it should (i.e., the OSC outputting the proper level), one should enable the oscillator, and assign it to each channel in turn, while monitoring that channel's output signal level, and twist the Trim pot until the channel outputs 1.228 Vrms (or whatever level you'd like to use for nominal, though I'm good with 1.228Vrms). Apply to each channel in turn.
^^ Question one - does that sound correct?
Next issue - my unit does not output 1.228 Vrms out the TRS when oscillator is enabled. It outputs 1.116 Vrms.
My assumption: While routing the 1.116 Vrms oscillator signal to each channel, I want to twist the Trim pot to yield a 1.116 Vrms signal on the channel output, in order to calibrate to 1.228 Vrms (in light of my out-of-spec oscillator output).
My reasoning: The Trim pot is probably a simple voltage divider after the gain stages of the channel. As such, output should be a linear function of signal level before the Trim pot. The oscillator signal is likely being injected after the gain stages, and before the assumed voltage divider Trim pot. The cal procedure would set the output signal to a fixed ratio voltage divider - this ratio would be identical between the oscillator output at the OSC TRS, and the output at the channel out, regardless of the actual oscillator output. Therefore, if my oscillator was outputting 1.228 Vrms as the manual states it should, then the output of the channel would be 1.228 Vrms.
^^ Question 2: Do these assumptions seem valid?
Old 10-08-2019, 04:33 PM
Default Re: Avid Pre calibration question
OK, I'm floundering. Any help would be appreciated.
Seems my assumptions above on how one is to calibrate the Pre are incorrect.
First, while enabling the OSC and enabling INS on a channel does route the OSC signal to the output. However, using this routing, the Trim pot for that channel has exactly zero effect on the output as monitored on the DB25. Accordingly, from my naive viewpoint, the ability to route the OSC signal to each channel's outputs is useless for calibrating the Pre itself.
I can't imagine digi would have implemented a feature that has no use, so I must be confused about something. Perhaps its utility is to calibrate something (e.g. an ADC) downstream? But even so, such utility is hampered by the fact that the OSC level (on my admittedly possibly compromised unit) is somewhat below the manual spec. What am I missing?
Next, I envisioned/postulated the following cal mechanism. I used a TRS to route the OSC signal to each channel's line input in turn. I set the measured channel to line, and 0dB gain. I was gratified to learn the the Trim pot in this case did indeed affect the channel signal output at the DB25.
Figuring that 0dB gain indicated on the GAIN/PARAM display corresponds to an actual 0 dB gain from Line input to DB25 output, I tweaked the Trim pot to make the measured signal level at the DB25 equal to the measured signal level (when unloaded - maybe a small error introduced?) at the OSC TRS output. Or very close - approaching this level, channels stop changing level with additional pot rotations.
At the point that the pots stop affecting the output level, I measured the following unloaded Vrms levels:
OSC TRS: 1.184
Channel outs - 1.171 to 1.183, with the low reading being quite the outlier.
I'll consider this good enough for the work I'll be doing, unless I've made some error in procedure.
Anyone want to comment on how I went about this?
Old 10-19-2019, 07:54 PM
Wrong subforum? Stupid question? Nobody has a clue?
Old 10-20-2019, 05:25 AM
arche3's Avatar
arche3 arche3 is offline
Why do you want to calibrate the pre? I suppose we can start there.
Sent from my SM-G975U using Tapatalk
Old 10-20-2019, 06:29 AM
LDS LDS is offline
OSC TRS: 1.184
That sounds as good a game plan as I have heard. Have you tried taking a measurement with the gain set higher? Maybe +12? To see how well the Pre actually maintains those calibrations in real world use.
Ambisonic recording is a big reason why you would want the preamp calibrated. You need closely matched gains on all channels for the decoder to work properly. One of the upsides of the PRE is that Pro Tools will automatically link channels based on the track type you create. 1st order ambisonics = 4 linked channels.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 10-20-2019, 01:24 PM
So metering is consistent with actual signal levels throughout my system.
Old 10-20-2019, 02:22 PM
arche3's Avatar
How are you using the pre? Microphones? Summing mixers? If microphones I don't see the need to calibrate. If bringing level up from summing mixer the metering is not needed imo as all that matters is the adc level into protools. You can calibrate the input on the audio interface for pairs of mic pre outputs of the digi pre.
I'm not even sure what the trim pot does on the mic pre units.
Old 10-20-2019, 02:35 PM
the.engineer the.engineer is offline
Sorry if I’ve missed this...have you measured the output with a volt meter to double triple check it’s outputting 1.228V?
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 10-20-2019, 05:11 PM
Good suggestions above. Here is how I would try it(not knowing any better). I would create a session with an AUX track sending(use the Signal Generator plugin) a 1KHz tone out any output NOT in use for monitoring. Patch that(with a physical cable) to each input of the Pre and feed each channel to a separate track in Pro Tools. Put those tracks in Input mode and watch the track meters. Compare against each other(adjust trimmers on the Pre for identical readings). And, compare against the output level of the signal gen track. This might not be technically "perfect", but certainly can result in matching levels
I also would likely look at the Pre levels and choose a target level that matches the highest number of channels that match before you tweak
Someone more technically savvy than me can likely figure a way for this to be done to actual technical accuracy
Old 10-21-2019, 08:45 AM
Good idea. I'll do that.
Question for Avid Tech Support: Omni Calibration Jack Ruston UK Pro Tools TDM Systems (Mac) 5 10-07-2011 08:08 AM
192 calibration question robsubway Pro Tools TDM Systems (Mac) 0 09-12-2006 09:25 AM
another question about calibration !!! vudoo Post - Surround - Video 15 03-02-2006 07:09 AM
192 calibration question theboat Pro Tools TDM Systems (Mac) 0 12-11-2003 04:41 PM
Calibration question.... Vpr500S Pro Tools TDM Systems (Mac) 1 10-23-2002 10:08 AM
