Old 09-14-2019, 03:30 AM
Whiteroomstudio Whiteroomstudio is offline
Default Re: D command ES with PT BASIC question
Thanks you so much for your help !
Old 09-15-2019, 01:15 AM
tklaavo tklaavo is offline
There's actually six soft keys on the D-Command, where user can assign functions (on multiple pages). I have Preview, write to selection, write to end, focus strip on/off etc... accessible all the time. Very convenient!
Tuomas
Originally Posted by reichman View Post
-soft key for Preview is buried, and if I remember correctly, "Write to selected" is not even on the same menu (wtf?)
-for tweaking plug-ins, there are more knobs on D-Command, but a lot less feedback. It's easy and fast to go through pages of plug-in parameters on Dock. Labeling is dynamic, feedback is better. iPad is more complicated, but it does A LOT. There are edit functions on the iPad that D-Command never dreamed of having.
-D-Command functions are pretty much fixed and not customizable like they are on S3/Dock.
Tuomas Klaavo
Helea Sound Post Production Oy
Old 09-15-2019, 10:07 AM
Thanks to everybody all those great infos !
Is there any way to test a D-Command just «*out of the box «* without being connected to a PT ultimate ?
When the unit is turned on only some of the switches turn on (and it is written «*offline*») meaning ... if I can’t see it in front of me and test it ... i take some risk ))anyone would have a solution (to be able to test a unit )
Thanks !!
Phil
Old 09-15-2019, 10:27 AM
reichman's Avatar
reichman reichman is offline
Tuomas is right. I may be overlooking some aspects of the D-Command in my short review.
Regarding the test, you should be able to go into "Vegas" mode which will tell you if every light and fader motor is working. I don't remember the keys to enable that mode, but it is computer-independent.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 09-15-2019, 12:28 PM
Southsidemusic's Avatar
Hey, you should be able to run the Vegas tests in offline mode as it has nothing to do with Pro Tools.
Vegas mode:
https://m.youtube.com/watch?v=61d2r0ZVRxc
https://m.youtube.com/watch?v=L8vE-PdFUj8
https://m.youtube.com/watch?v=LBfKb84GKFY
To enter Vegas mode: Press UTILITY > Test > LED > Vgas (Vegas).
More info here:
https://www.manualslib.com/manual/59....html?page=143
Best of Luck
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #16
Old 09-23-2019, 09:09 AM
Hi guys
my d command ES just arrived
Running perfect
Avid is doing an very good upgrade offer !
That was perfect timing to upgrade to Ultimate
Thank you all for the differents tips !
The unit has been reconized by PT in NO TIME ...
Now it is time to learn it a bit ))
Have a great day and thank you all !
P
  #17
Old 09-23-2019, 02:34 PM
Glad to hear! You will love that unit
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #18
Old 09-23-2019, 02:55 PM
reichman's Avatar
Yep. Enjoy! In about two days you'll wonder how you ever worked without it.
Nathaniel Reichman
  #19
Old 01-08-2022, 07:48 PM
js_nyc js_nyc is offline
Cut to 2022- I have a client who has an old D-Command (no X-Mon). He just obtained the 2021 PT Standard license. I tried to walk him through the menus remotely today- on a Mac Mini. In Setup he has the peripherals section, with either EUCON or Legacy Surface Controllers as an option on this menu. No matter which option he chose, after the scanning stopped, his D-Command did not respond. One time, he received a warning about not having the proper drivers. Would it be possible to obtain these D-Command drivers somewhere and run this surface on his standard PT configuration? Or is it still only limited to Ultimate software? Please let me know. Thanks.
js_nyc
15" Macbook Pro (Mid 2012) 2.3 GHz Intel Core i7
16G Memory
PT 10.3.11/ 12.5.2
003 Rack
OSX 10.8.5
ProToolsConsultant.com
  #20
Old 01-09-2022, 12:35 PM
LDS LDS is offline
There are no D-Command drivers. The functionality is baked into Pro Tools, which is part of the reason those old control surfaces still work with current versions despite the lack of active support for some years now. An ultimate license is required...
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Basic, basic recording question enigami MIDI 1 06-08-2009 06:27 PM
[D-COMMAND] HELP#3 - Basic operation dsstudio ICON & C|24 1 01-30-2009 12:36 AM
Basic 8 ch D-command Cawbaby ICON & C|24 8 11-21-2008 11:24 PM
Basic HD System with One 192 I/O and the Command|8 ASPSA Pro Tools TDM Systems (Win) 35 03-11-2007 11:41 PM
Basic Pro Tools use. Really Basic question. Shizznik_McRuube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2002 11:41 AM
