Old 08-11-2012, 02:52 AM
luts luts is offline
Default How do I get my 002R to playback anything other than Pro Tools??
This is so frustrating!!
I just want to watch you tube and here the sound therough my audio monitors (connected to my 002R)
What am I missing here?? should it be soooo difficult.
I go to system preferences> Sound
Then I switch OUTPUT to Digi 002R ..
Then... the sound still comes out of my computer and not my monitors!!
Why ?
And, why can't it be as simple as that??
Adam
Old 08-11-2012, 03:00 AM
petmar petmar is offline
Default Re: How do I get my 002R to playback anything other than Pro Tools??
I know what you mean. I often have to restart my MBP and then switch to get it to work. Not a solution but you're not alone
Old 08-11-2012, 08:07 AM
nst7 nst7 is offline
You might also need to go under Audio Midi Setup and select it there, and configure outputs 1-2 as the speakers.
Old 08-12-2012, 12:04 AM
Jacksonland Jacksonland is offline
Adam, have your 002 turned on before you start your computer, then go to preferences and select 002.
Old 08-13-2012, 11:34 AM
sd57deny sd57deny is offline
IF your are trying to play back internet stuff such as youtube there is a simple solution buy a cable that on one side is MINI JACK and the other 2 quarter inch split......plug it in to your aux input and then just put your monitor AUX button on.....now this is my solution for my 003 im not sure if that same auxilary monitor button exsist on the 002r ...best of luck
Old 08-13-2012, 03:53 PM
My suggestion as well. The 002 uses RCA for the Alt inputs, but the setup is the same. Simply hit the Alt to Mon button to listen to all non-PT audio I did that for years and never had any issue, other than the less-than-stellar sound from the onboard analog out. Adding a Presonus Central Station(or any monitor/source switcher) is also very handy, but I actually prefer to keep my audio machine disconnected from the internet as much as possible(I use a cheap off-lease PC for internet surfing).
No playback from 002R neilinda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-21-2005 02:37 PM
Monitoring during playback on 002R jazzmachine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-01-2005 04:11 AM
Possible to use MIDI on 002R to trigger playback? macaholic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-25-2005 01:29 PM
Cannot Playback DIgi 002r pwat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-04-2004 11:17 AM
002R Playback without Protools phdlowlife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-01-2004 12:45 PM
