Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 05-06-2015, 12:41 AM
Kregan Kregan is offline
Default Plug in Latency Compensation Question
Hey guys I run Pro Tools 8 LE on windows XP with some Waves plug ins. I was wondering if this statement is true..
"To further confuse the matter, it’s only fair to point out that Pro Tools LE/M-Powered does, in fact, have some degree of fixed latency compensation built-in and any plug-in latency that falls within the hardware buffer should be compensated for adequately by this."
Taken from: http://www.musictech.net/2010/12/pro...orial-latency/
So i'm really trying to find out if I put a plug in on a track and it has 64 samples of latency and my H/W buffer size is set to 512 samples, will there or will there not be any delay/latency?
Will the track play back exactly as I recorded them or will it be off set by 64 samples even though my buffer size is set to 512 samples in Pro Tools 8 LE?
Hope I communicated that OK, any help would be great... Thanks a bunch
Old 05-14-2015, 05:02 PM
Default
Didn't we see this same post a week ago in another thread? The compensation mentioned only relates to the buffer setting and would not correct for additional latency caused by plugins. If you have a mix going, that uses plugins with latency(and not all plugins HAVE latency), you should make those plugins inactive(not bypassed, but grey'd out) to do any overdubs.
Plug in latency compensation, have I got this right... owenmorgan Tips & Tricks 0 03-14-2010 07:19 PM
No plug-in latency compensation on LE / M-Powered? yeloop Pro Tools M-Powered (Mac) 5 09-14-2009 07:57 AM
Latency Compensation Plug-in?? When?? Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-29-2004 11:38 AM
Plug in latency compensation with AV option ModernMusic Post - Surround - Video 1 04-25-2002 10:15 AM
PT 5.1 / plug-in latency compensation? Felix General Discussion 11 01-16-2002 12:52 AM
