Old 07-02-2020, 04:29 AM
Default Arturia Mellotron issues
Just updated all my Arturia instruments a couple of days ago and the process went okay. What isn't okay is the updated Mellotron instrument. Insert it on a stereo instrument track and it plays fine. The problem starts when you hit the spacebar to stop PT's transport. I get a crackling/stuttering sound as the transport stops. Happens no matter what sound I call up in it. Corrupts the session to the point that saving & closing the session doesn't help - I have to quit PT and restart the session.
Number of tracks doesn't matter but if I have other tracks active that are audio it will also sometimes throw up a 9173 error.
Everything else from Arturia plays no problem so it's just this one synth. Will investigate seeing how things work when I host the Mellotron in VEPro 7.
edit for additional:
Hosting in VEPro 7 doesn't give me the crackling/stuttering sound. I do get a slight pop/tick sound when I stop the PT transport. No 9173's if I have other tracks in the session. Once again VEPro to the rescue.
Jack
QAPLA!
Last edited by musicman691; 07-02-2020 at 04:43 AM. Reason: added additional testing in VEPro 7.
Old 07-02-2020, 06:37 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Arturia Mellotron issues
I'm still on V6 so no Mellotron here yet. However, have you tried a higher buffer setting? Also, a new Session with just the Mellotron and the associated MIDI data?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 07-02-2020, 12:11 PM
Stephen
Tried both and the result is the same. And once the MIDI is recorded I switch to a higher buffer setting like 512. Arturia every once in a while pops out a synth that is a cpu muncher. Early revisions of the MiniMoog would eat cpu cycles like crazy. This is just anther one like that.
Jack
QAPLA!
Old 07-02-2020, 02:34 PM
Yeah they seem to go through the revisions.
Either way, great to get regular updates! Hope you get one soon.
Stephen
Old 07-02-2020, 02:47 PM
ChuckS ChuckS is offline
Try running it in the Analog Lab plug as a workaround.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 07-03-2020, 04:33 AM
Same problems. Analog Lab is really just a shell for the synth engines themselves. You just can't edit the sounds without having the specific model itself.
Jack
QAPLA!
Arturia Issues dustpan AAX Plug-ins 2 04-30-2017 05:02 AM
Issues with Arturia's Analog Factory SE Amnesiac Virtual Instruments 0 03-23-2009 08:47 PM
Mellotron TFL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-18-2005 12:43 AM
mellotron disc help classictw Digidesign Hardware & Software 1 08-29-2003 06:50 PM
mellotron for sale in nyc..... the duke ProControl, Control|24, Command|8 0 11-11-2001 01:59 AM
