Protools efficiency......
Hello everybody!
I recently bought a new Sony Vaio, pentium 4 computer running at 2.8 Ghz. Ever since i connected to the internet, protools' sound quality has decreased. my question is: to obtain the best quality of sound with protools should my computer only be used for recording purposes? Does the internet affects protools efficiency? Please help me!?! Thanks Alot |
Re: Protools efficiency......
Best using PT offline.
Try disabling your Internet Device (Ethernet card, Modem, USB modem, whatever it might be?) in the device manager before starting PT and see if that helps. If you have a Firewall and AV program running you can temp disable them too before starting PT, take a look at your task manager in XP (Ctrl + Shift + Esc) and sort by CPU/Memory in the processes tab, this will give you an idea whats eating up your resources. There are ways to make it work for that "all in 1" machine, I prefer installing 2 seperate XP's on seperate partitions (this called Dual booting), then you could either disable your Internet devices or remove the Internet device drivers completely on the PT XP install and have no AV programs, Firewalls or Tray apps, nothing but your audio stuff on the PT one and everything you need for net on the other, you get the idea? |
I did virtually the same thing by setting up two separate hardware profiles on the same drive (too broke to buy Partition Magic!) I have a default setting and a ProTools setting and have to choose one for each reboot. The ProTools setting is stripped down to the essentials, the default setting has my screen saver, wallpaper, internet stuff, network card, etc.
Works for me! I learned how to do it from www.blackviper.com |
PT 11 efficiency? | climber | Pro Tools 11 | 6 | 09-12-2013 09:16 AM |
PT 9 Efficiency Questions | michaiel | macOS | 3 | 02-13-2011 10:15 AM |
Osx vs Win7 efficiency? | tamasdragon | General Discussion | 4 | 05-02-2010 11:45 PM |
Protools efficiency...... | Synchrometer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-08-2004 06:54 PM |
increasing the CPU efficiency... | aziel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-02-2003 05:35 AM |
