Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 07-02-2017, 02:22 AM
antorollo antorollo is offline
Default sizzling problem , PT first and scarlett solo 2nd
Hi ,
Since I have installed PT first , i can't used it , because everytime there is sizzling when I listen my project , when I record track . I updated all the drivers and nothing .
Please Help me , I don't know how can I stop it !
Thanks
Old 07-02-2017, 04:25 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: sizzling problem , PT first and scarlett solo 2nd
Try Reaper and see if the problem remains. If so, it's a problem with your interface and/or your computer. If the sound goes away, PT is having a problem with your interface and/or computer.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-04-2017, 11:29 PM
thank you
I try tro repair but nothing . the sizzle almost disappear when I delete a track with a lot of reverb .
yesterday , while 1 hour , I could used the software without sizzle .and after the sizzle come back .
Old 07-05-2017, 11:30 AM
The Weed's Avatar
Not repair, REAPER - another DAW - to be sure it's a Pro Tools issue and not your interface's hardware and/or drivers. Go to www.reaper.fm.
SonoBus
Old 07-05-2017, 01:19 PM
Southsidemusic's Avatar
Can you please add more info about your setup like complete computer specs and what hard drives and models aswell as interface etc since we cant help much otherwise.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-05-2017, 10:21 PM
Awesome Music Studio Awesome Music Studio is offline
I've experienced a sizzling sound like you described before, typically when I'm doing too much at the same time.. like having a Flash Game running or something like that. See what things are taking up too many of your computer resources and remove some if you can.
You can also try increasing the amount of host processors in Setup - Playback Engine .. but usually when that's a problem, its more of a crackle not a sizzle.
Hope this helps
Old 07-08-2017, 04:53 AM
ok , the problem isn't the software I think because sometimes there is no sizzle and I did a project with one track and no sizzle .
My config
windows 8.1 64 bit
mothercard asus h81l plus
process intel core i3 4130 3,40ghz
ram 8gb
Amd radeon hd 6570
and focusrite scarlett solo 2nd
pro tools first
I think the problem it's the process or a plug in , but when I go in playback engine , I can't increasing the amount of host processors .
thanks for you help
Old 07-08-2017, 05:33 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Some Scarletts don't like low buffer settings, I would try to set at no less than 512
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 07-08-2017, 06:09 PM
Intel i3 CPU might be a real issue here aswell.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Scarlett Solo's I/O Setup Greyed out JollyGreen Pro Tools 12 17 11-27-2017 03:58 PM
Scarlett 2in1 solo studio and Protools First mateuszkluzik8741 Pro Tools | Intro Discussion 3 02-06-2017 12:09 PM
Newbie questions about audio interface (Focusrite Scarlett Solo) sb_stefan Third Party Interfaces 1 12-22-2015 06:18 AM
Problem with Focusrite Scarlett 2i4 with Pro Tools 11 on Windows 7 Bloodstone_90 Third Party Interfaces 4 01-23-2015 02:17 PM
