Old 10-21-2011, 12:02 PM
puffin puffin is offline
Default Clip gain
If sound editorial uses 10 and takes advantage of the clip gain feature, will that data show up in a 9HD session after import?
I wish to migrate editorial to PT 10 first and then my main mix rig.
Old 10-21-2011, 10:38 PM
blairl blairl is offline
Default Re: Clip gain
Pro Tools 10 will allow you to save the session as a Pro Tools 7->9 session. However, any clip gain settings will be lost. There is a warning dialog with this information when you save the session to the 7->9 format.
You can render the clip gain in Pro Tools 10 before saving as a 7->9 session, but of course this will be permanent.
Old 10-21-2011, 10:40 PM
Dism Dism is offline
You can also choose to save clip gain as volume automation instead if you don't wish to render the clip gain.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
How to use X-Key on clip gain? Frank Kruse Post - Surround - Video 6 11-01-2011 11:14 AM
