Old 11-23-2009, 01:16 AM
hoss33 hoss33 is offline
Default mixer meter not responding to fader
Hi, I have a probably very stupid question, but I am new to Pro Tools (LE 8.0.1), I am coming from Cubase 5.
When I am mixing my audio tracks and move the faders the volume goes up and down according ot the fader, but the meter (to the right of the fader) does not change and still shows the "input signal" from the track. Even if I mute a track the meter keeps on dancing.
Only the master fader works the way I am expecting.
Where can I change the setting to have the actual track output shown in the meter?
Old 11-23-2009, 02:50 AM
musicalavtech musicalavtech is offline
Default Re: mixer meter not responding to fader
In the menu-options-pre/post fader metering. Page 59 of menus guide.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 11-23-2009, 03:59 AM
Thank you very much.
Old 11-23-2009, 07:09 PM
XanderMoser XanderMoser is offline
Just be careful when post-fader metering. If you have the fader down below 0, you may be clipping and not be able to see it on the meter. The point of pre-fader metering is to be able to keep an eye on all of your levels, no matter your fader position
Old 11-23-2009, 10:21 PM
Thanks again. It's cool to be able to switch post/pre.
Pro Tools Mixer Faders/Peaks not responding sweetambition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-10-2012 03:33 PM
Fader not responding to touch PTPerson ProControl, Control|24, Command|8 5 06-09-2012 12:29 AM
Peak meter not responding? luqiao Pro Tools M-Powered (Mac) 3 12-26-2009 03:33 PM
PT8LE Mixer Faders/Knobs stop responding!!! IGRA_Warsaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-27-2009 04:41 AM
Fader Meter Behavior in PT8 and Fader Weights DrFord Pro Tools TDM Systems (Mac) 4 01-08-2009 02:23 PM
