Old 09-26-2005, 05:47 AM
Allbaldo Allbaldo is offline
Default How does one \"allocate more memory to DAE\"?
I'm running a D24/DSP Farm/2xMix Farm/1.25GHz G4/10.3.8, and anytime I'm recording more than about 4 tracks I get a spinning beach ball everytime I hit record, then a message that says "please allocate more memory to Pro Tools". I've been searching around, and can't find any way to allocate this memory. Any help would be REALLY appreciated. Thanks!
Old 09-26-2005, 06:14 AM
timc timc is offline
Default Re: How does one \"allocate more memory to DAE\"?
What version of PT is one running?
Old 09-26-2005, 06:26 AM
trakbytes trakbytes is offline
Judging from your post, I think you are running a totally unsupported system. I don't think the D24 is supported on OS X, any version. You're sort of tricking the system into thinking it is a Mix configuration, but it's really not.
Your system will work well in OS 9, PT 5.1.3. Either stay with that or upgrade the D24 to a Mix core card and run PT 6.4.1. You can't manually assign memory to an application in OS X; it is done dynamically according to the application's needs.
Just out of curiosity, and the odd chance that it might work, do you have a Mix Farm as your first card in the slot order? The D24 is basically just a dongle that allows Pro Tools to launch and doesn't really have any DSP processing power. But a Mix Farm card has to be first in the card order for Pro Tools to see it a Mix system.
Bob
Save early and often! (or once a day whether you need to or not...)
Old 09-26-2005, 07:08 AM
Sorry I was a little incomplete in my post. I'm running 6.4.1, and my card order is Mix Farms, D24, and DSP Farm. Thanks!
Old 09-26-2005, 09:18 AM
Pg. 40 of the 6.4 manual...
Choose setups>Playback Engine
From the DAE Playback Buffer pop-up menu, select a buffer size
Click OK
Restart
Old 09-26-2005, 09:28 AM
Seeee Seeee is offline
that is a MIX system. dont listen to trak (sorry), it is supported up to 6.4.1.
Why Can't I allocate more memory? AINSLIE Pro Tools TDM Systems (Mac) 12 01-03-2008 08:55 PM
Memory is Low? Quit and Allocate more memory to PT Unite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2004 05:38 PM
How do I allocate more memory soma323brooklyn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-16-2003 05:35 PM
How to allocate memory? Smakrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-17-2003 02:31 PM
Help!! Allocate memory? Craig Woolard Pro Tools TDM Systems (Mac) 1 03-26-2002 03:19 AM
