Old 12-05-2015, 09:29 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Time adjust on MIDI
If there's a way to do this, I'm not finding it in the manual. Is there a way to do a time adjust in a MIDI clip like you can an audio clip? I had a MIDI clip and I wanted to experiment with having it run at double time and also 1/2 time to the session tempo. Its easy enough to do with elastic audio, but I can't find a MIDI track equivalent to do the same thing. I know I could commit to audio and then use the EA, but I was hoping there was a way to do it with MIDI as well. I can't just change the session tempo as that will mess up other MIDI tracks and such. Thanks.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 12-05-2015, 12:58 PM
Default Re: Time adjust on MIDI
Change the session tempo(BPM) to double and half of the current setting. Midi tracks will change to match. Audio that's in Samples mode will be unchanged. Audio that's in TICKS mode might change(WILL if EA is enabled, can't remember if EA is not enabled)
Old 12-05-2015, 03:59 PM
Glenjb Glenjb is offline
What Dave said and also if you have other midi or instrument tracks you DONT want to change in tempo etc..., change them from ticks to samples
Old 12-06-2015, 10:13 AM
DonaldM's Avatar
Dave - Yeah, I know that part. I was hoping there was a way to time change a MIDI clip like you can an audio clip using EA. Apparently not. It might be a nice future option with MIDI to do that. Like with Boom, you can set the loop to play at tempo or 2x or 1/2 as I recall. That same feature resides in some other VIs as well, like Transfuser. Be nice to be able to, say, right click on a MIDI clip, select something like "change tempo" and have options like 'session tempo', '1/2 session tempo', '2X session tempo', etc. Make it a bit easier to experiment with arps and loops with various sounds. That's what I had in mind when I first posted on this.
The issue with changing the entire session tempo for one MIDI clip is what's already been stated...making sure it doesn't affect any other MIDI, Instrument or audio tracks. And it is cumbersome when you just want to experiment. Anyhow...just a thought and vote to make this a MIDI feature in some future upgrade.
Old 12-06-2015, 07:12 PM
Hey Donald, switch the track view to region and create a region group if separation exists, then use the TCE tool to compact or expand the region boundaries.
Aaron Mulqueen - 001 HD Native
Old 12-07-2015, 10:41 AM
DonaldM's Avatar
Thanks, Aaron. I haven't thought of this approach. I'll try that and see if it does what I'm looking to do.
Space plug in,how to adjust T60 time? Rockman413 Pro Tools 12 0 09-29-2015 03:21 AM
Adjust Session Start Time Issues anders Post - Surround - Video 7 01-11-2013 02:08 PM
Every time I adjust volume it zeros to the bottom phatbeatstudio Pro Tools TDM Systems (Mac) 3 07-12-2012 09:53 AM
How to adjust tempo in real-time? ddecker1979 Tips & Tricks 1 09-15-2010 06:28 AM
Crossfades-"Adjust Bounds" every time??? cloughri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2007 11:39 AM
