Old 11-05-2019, 02:55 PM
Default Difference between ctrl-X and cut all automation?
does anyone know the official name of the ctrl-X shortcut that I believe is undocumented and essentially cuts all automation through all lanes but only when at least one lane of automation is shown. Versus the cut all automation command that always does just that?
I was wondering what the intended use of ctrl-X is?
Thanks!
Frank.
Old 11-05-2019, 03:49 PM
Reckless Erik Reckless Erik is offline
Default Re: Difference between ctrl-X and cut all automation?
Control X ramps between the break points whilst cut has no ramping and the auto value is written using the value at the selection start point. Control X is nice when you want to "crossfade" automation parameters.
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 11-05-2019, 08:28 PM
bewk's Avatar
bewk bewk is offline
I use it often when EQ-ing a cut of music under DX for talking head interview stuff. Mostly to brute force some of the instrumentation out that multi-band dynamics isn't chewing on with enough teeth. As mentioned above, I use this to ramp smoothly out of the EQ for that section back to "flat" over time so that the change in EQ isn't obvious. I use it in other ways too but this is a constant in my workflow. Kind of like "AutoMatch" but with a variable length.
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA
• PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD)
• Avid Dock, iPad 7th gen & EuCon 2023.11
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1.4
www.quesound.com
Old 11-05-2019, 11:14 PM
Thanks! But isn't cut all auto exactly the same? Only that you don't have to show a lane first? I have used cut all auto to create ramps across all visible and invisible lanes for all these years before someone told me about ctrl-X yesterday.
Frank.
Old 11-05-2019, 11:29 PM
thierryd thierryd is offline
Checking in here remains as useful as ever I never heard of ctrl-X. Thanks for mentioning!
Greetings,
Thierry
http://www.a-sound.com/
Old 11-06-2019, 01:36 AM
Yes ctrl-x is an odd one.
Old 11-06-2019, 03:27 AM
Sonopolis Sonopolis is offline
BTW, so does CTL+Shift+X for Clip Gain. I use it to ramp Clip Gain changes inside regions all the time
Old 11-06-2019, 03:31 AM
Yeah but that won't cut any automation break points, just clip-gain.
Old 11-06-2019, 06:58 AM
bewk's Avatar
I think they're the exact same thing, but as you mentioned, it just isn't documented. Ctrl-X still cuts all lanes of automation even if the track is in waveform view.
www.quesound.com
Old 11-06-2019, 07:56 AM
Not quite. At least not here. ctrl-X will chop away actual audio when you are in waveform view and in that case won't touch any underlying lanes.
If you want it to cut through all lanes and not chop audio you have to have one auto-lane visible, which one doesn't matter. Only then it won't touch your clip and cut through all lanes.
opt-shift-x will always cut all automation regardless of what you're looking at and won't cut clips.
ctrl-x almost feels like something they started programming and then stopped at some point and never finished it (?). It's a pretty odd one. One keypress less though ;-)
HTML code is On
difference between MIDI automation and Audio automation on Instrument Track? mariam Getting Started 5 04-28-2016 03:55 PM
What's the difference between clip gain and volume automation on audio? rockguitarist1255 Pro Tools 10 7 12-27-2012 07:20 PM
fine tune automation with ctrl stevedresser83 Windows 7 05-10-2011 01:47 PM
ctrl+tab or ctrl+alt+tab not working Sebastien Richard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2006 10:10 AM
Trim Automation with 6.9 and CTRL 24 tonicjeff ICON & C|24 2 10-25-2005 12:50 PM
