Asio4All and pro tools not collaborating
Im away from home for a few months and would like to do some basic mixing. I left the mbox back in the states and brought only my lap top and the ilok.
Its my understanding that pro tools 10 can operate without an interface as long as you use asio4all as a substitute. I have asio4all downloaded and installed, but pro tools will not recognize it and will not open, I'm stuck on the "the selected ASIO audio device could not be initialized. Please select another ASIO device." The playback engine window has no other options besides the m box. ASIO4ALL is not listed. Please Help & all wisdom is much appreciated! |
Re: Asio4All and pro tools not collaborating
If "ASIO4ALL V2" is not listed as an available device, then it wasn't installed properly.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Im on Windows 7 64 bit. using pro tools express 10.3.3
Ive tried the n key trick but the only option for my playback engine is the m track quad asio, there no drop-down menu, just that one option. I'll try to re-install asio4all. Any other advice? thanks! |
My sound card is Cirrus Logic. In the off-line settings for asio4all, it says that this is enabled.
Its my understanding that pro tools 10 can operate without an interface as long as you use asio4all as a substitute. I have asio4all downloaded and installed, but pro tools will not recognize it and will not open, I'm stuck on the "the selected ASIO audio device could not be initialized. Please select another ASIO device." The playback engine window has no other options besides the m box. ASIO4ALL is not listed. Please Help & all wisdom is much appreciated! Im on Windows 7 64 bit with protools 10.3.3 tried the n key thing! |
Isn't PT Express locked to just the one audio interface?
Correct. From Pro Tools Expert:
"However Pro Tools Express is different from the other versions in the fact that the only difference between Pro Tools Express and the regular version is a limited track count and a few less plug-ins. Other than that, what you get with Pro Tools Express is Pro Tools 10 free with an Mbox or Mbox Mini. It is tied to the Mbox and also requires an iLok, so you can’t use this version of Pro Tools with any other interface, or no interface for that matter." Time to update to Pro Tools if you want to use your internal soundcard. Cheers,
No Sound Pro Tools HP Laptop asio4all | malmalibu | Windows | 14 | 11-25-2013 04:47 PM |
Pro Tools 10 asio4all no audio | malmalibu | Windows | 3 | 08-29-2013 06:19 PM |
Help needed using USB mic with Pro Tools and ASIO4all | rockguitarist1255 | Pro Tools 10 | 6 | 06-30-2013 02:09 PM |
Pro Tools 10 & ASIO4ALL on a Mac running Windows | aj88keys | Pro Tools 10 | 1 | 01-09-2012 01:39 AM |
ASIO4ALL and Pro Tools? | Diesel1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-12-2005 08:01 AM |
