Protools freezes at the loading dae screen
Hi I'm Dae... .
A few days ago I clicked to open protools and it couldn't get pass the "DAE LOADED" screen. The plug-ins loaded pretty fast but it stopped at the "DAE LOADED" screen. I hav ea Mac G5 OSX 10.5.7 POWER PC 2G DDR SDRAM. I really need help. I'm at the dawn of this new project and I'm already a day behind. PLease anybody if you can help me. I updated my combo. I've look through the compatability list. I removed all plugins. Help Me Please ! THANK YOU |
Re: Protools freezes at the loading dae screen
I had that the other day. Blew away all my preferences, emptied the trash, and reboot my Mac. When it came back up no more error.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
OK Give me a step by step... directions on where to delete my prefrences....
The quickest way to get up and running is to put all of your Plugins into the 'UNUSED' Plugin folder.
You can find the Plugins folder by going to Applications/Digideign and you'll see a shortcut to it there. Click it, and then go up a volume (Apple + up) and then you'll see both the USED and UNUSED folders. Drag all the plugs from used to unused. Then try and boot PT. If it boots then you know you have an RTAS plugin problem. Put 50% of the RTAS plugins back in the USED folder and boot again. If it doesn't boot then you know that the culprit is in there, if it boots then the culprit is in the UNUSED folder. If you watch when you boot PT you might see when the DAE freezes - the Plugs load alphabetically so you might be able to narrow it down. When you've got the culprit, then you'll need to update that plugin or contact the company to check with issues etc.... As for deleting the preferences and all that, you'd be better off using the 'Tech support facility' - nice and easy: http://www.digidesign.com/index.cfm?...4&itemid=25974 http://web.mac.com/jcdeshaies/Delete...Bienvenue.html all the info you need on basic troubleshooting is here: http://duc.digidesign.com/showthread.php?t=54888
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
Thanks man... but I figured it out my problem exactly....
http://duc.digidesign.com/showthread.php?t=251875 I still don't have the answer but I now know the problem! |
Digi 002 not loading...it freezes with the words "loading" on the screen | teketuco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-09-2012 05:42 PM |
Music Production Toolkit & Pro Tools LE 8 freezes at loading screen | philbagg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-25-2011 07:05 AM |
Protools LE 8 freezes when loading! | musiclovin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-11-2009 10:49 AM |
ProTools 6.7 freezes at "loading DAE objects" | eljodon | Pro Tools TDM Systems (Mac) | 7 | 01-16-2005 06:44 PM |
system freezes on first loading of protools le during LAUNCHING DAE screen | boy365 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-22-2001 10:22 AM |
