#21
Re: Dual G5 1.8 will smoke a PB 1.5 with 002R righ
Excellent! |
#22
from that document you can clearly see that both pci & firewire busses are connected to the very same i/o device controller. and from the same picture you can see why people recommend turning airport off when running protools well, granted, it's not 100% same way if one is called "firewire phy" and another "cardbus bridge", but that doesn't matter - the point is nothing is between them and the controller.
#23
#24
Re: pb 1.5
i have a 1.25GHz powerbook and often do such a live project that involves FOH mixing, monitor mixing and recording all at once. i take 16 inputs, give 4-8 outputs, use external reverb via spdif i/o and usually have like: - 10-12 URS eq's - 5-8 focusrite D3 comps - 4-5 bombfactory 1776 limiters - 2 McDSP multiband comps - some PSP plugs i have to leave a good cpu headroom since i cannot afford a hiccup in a live situation. i don't use waves' stuff much, but from my experience from using a lot of other plugs i would say you should be able to do what you described. i believe the C4 pretty much equals to the mcdsp multiband (cpu-wise) and if there's a difference, the focusrite/urs stuff should tax cpu more than waves' stuff. that's however nothing more than a feeling. if you want to make your system more efficient, use an external reverb. even the cheapo t.c. m300 sounds nicer than most plugin reverbs and it has 0% cpu tax
#25
JFreak, you rock!
"The secret in life is to have no fear" Fela Anikulapo Kuti |
#26
wow,
Perfect setting: Small private VIP venue (75 capa) with UPA kit, midas board, plenty standard outboard (dbx, bss, tc verbs...) Band: rock, guitar driven 4 piece combo with good sources and stage experience. 1st time for me as I was subing the main guy... Tried the waves L2 on the mix but was not appropriate as I had plenty of headroom and did not need volume. Also, the vintage warmer was nice on the vox group, added nice upper harmonics, (dpr 404 de-esser took care of the 6k...) Then switched the l2 for the BF76 (I know...) and it f8@# rocked!! Fast attack, fast release... super nice gain riding with great tone, tight low end... Buffer setting: 128 samples, almost unnoticeable latency. The manager flipped, the band flipped, the house engineer flipped, I flipped! Only snag: The plugs did the riding, at one point I was telling myself, wait a minute, I'm not mixing anymore...! Seriously, the only glitch I see is that damn 1394a port on my powerbook is not latched and the firewire can get unplugged... Very nasty so taped it good. I'm thinking about getting a cardbus to 1394a and use the 1394b port on my pb for the external drive. That way I'd have the 002r on the pci bus separated from the firewire bus who would be dedidated to the drive. Good idea right? Now, is there such a thing as a carbus to 1394a adapter that locks or latches the firewire connector?? Lets just say it would reassure me a tad... All in all, it was a good experience and I played safe with only two plugs inserted on vox group and mix. I will expand on this though... Woohoo, just won an hitachi travelstar 7200rpm on E-bay...150$ Speed? Bring it on!
will I be OK with the G5 dual 2.3 DC and the 002r | pimp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-22-2006 09:35 AM |
G5 Dual 1.8 2nd gen with 002R and PT7 | Ken P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-15-2005 05:49 PM |
Does Dual 2.5 Smoke Dual 2.0 with 002R? | John J. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-20-2005 11:30 PM |
G5 Dual 2 Ghz and 002r | kraster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-14-2003 11:40 AM |
dual g4 and 002r | stewie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-24-2003 09:45 AM |
