Old 10-03-2015, 03:14 PM
Fezzler Fezzler is offline
Default Alternative to Waves MV2?
Anyone know of any alternatives to Waves MV2? I kinda hit my budget on plug-ins and software and it looks like a useful tool.
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3
Old 12-07-2018, 08:08 AM
Ben Wood Ben Wood is offline
Default Re: Alternative to Waves MV2?
Xfer OTT is free....
Old 12-07-2018, 09:02 AM
amagras amagras is offline
OTT is a multiband compressor, MV2 is a low level compressor. I don't know any cheaper than MVP when it's on sale, right now it's $29, check out your personal daily deals or use my code and get it for around $26 or even cheaper if you are lucky to combine both
https://www.waves.com/r/xhwkze
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 12-07-2018, 11:43 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
According to Jack Joseph Puig there is NO alternative. He said if Waves stop it he is leaving
His tip was to use it on vocals. It does something no other plugin does on the voice.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 12-07-2018, 12:44 PM
Stephen
The technology is borrowed from C1 but the simplicity of MV2 (just one fader and output level) is unbeatable, even by MaxxVolume so JJP is essencially right.
amagrasmusic.com
Old 12-07-2018, 02:33 PM
reidj reidj is offline
I love this plug in and I think it's very underated. I use MV2 or surround MV360 in 75% of my tv/doc mixes. I'm not aware of another low level compressor that's as easy to us as this.
Old 12-07-2018, 03:09 PM
Mikey MTC Mikey MTC is offline
Its magic is that it can simultaneously turn down stuff that's too loud (like a conventional downward compressor) and also turn up stuff that's too soft.
It's awesome for that and it's easy.
If you want to tweak, look at the McDSP ML4000. It can do the same thing (and more!) in a four band multi-band configuration giving you control of absolutely everything - with a mastering grade limiter on the output to keep it all in check.
Both of these are underrated plugins for sure!
Old 12-08-2018, 01:06 AM
https://www.waves.com/1lib/pdf/plugins/mv2.pdf
"The Compressor function is similar to that of Waves Renaissance Vox."
Stephen
Old 12-08-2018, 01:39 AM
Stephen
Yes, that's the other half of it, part of what makes it so useful, but not unique
amagrasmusic.com
Old 12-24-2018, 10:30 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
The original post is 3 years old!!
IMDB
HTML code is On
Alternative to WAVES Blindman13 Pro Tools TDM Systems (Mac) 32 01-01-2015 06:52 AM
Waves Surround Bundle alternative garnoil Post - Surround - Video 8 06-02-2009 03:27 PM
Good alternative to waves L2 ? Ru_C Pro Tools TDM Systems (Mac) 18 09-20-2007 08:25 AM
Alternative to WAVES Plugins? SonicWorx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 02-18-2006 03:37 PM
alternative to buying waves bundles? woodbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-10-2004 06:31 AM
