Old 12-23-2020, 08:05 AM
[email protected] sleshnyc@gmail.com is offline
Default new computer drive swap questions
Currently running pro tools 2020 on a mac 5,1 6 core machine. Just bought a 5,1 12 core machine. Can I just pull out the hard drive from my old machine and pop it in the new one? Is there anything you are aware of that I need to 'uninstall' from my old computer first, software wise? Everything is either licensed to the drive or in the cloud, correct?
Anyone with experience doing this?
Old 12-23-2020, 10:02 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: new computer drive swap questions
Yes
Janne
Old 12-23-2020, 10:29 AM
You may find a few plugins might require re-authorizing, but it should be an easy move.
Old 12-23-2020, 12:59 PM
crizdee's Avatar
crizdee crizdee is offline
I placed the same drive into a different computer recently and lost quite a few auths. i think most go by the machine ID not the hard drive.
There might be some that need you to un-auth first, but don't do anything till you've tried.
Cloning the original drive and leaving the clone in the old machine might be enough to be able to un-auth if needed.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-23-2020, 01:40 PM
JFreak's Avatar
If you habe both machines available when you do the switch, you can swap the drive back and forth as long as all machine auths are deactivated on old and activated on new. In this case no need to clone anything. Also remember some iLok licenses may be machine authorized nut that part is easy. Harder to find challenge-response codes
Janne
Possible to swap the 500GB drive of DD-GT? Frank Kruse Aspera DigiDelivery 1 07-19-2007 09:37 AM
OT: Internal Drive and FW drive swap CharlesL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-21-2003 07:42 AM
Looking for a FireWire / IDE* Hot-Swap Drive Systems cutyhoney Pro Tools TDM Systems (Mac) 1 07-18-2003 08:04 PM
Digi: Will I be able to just swap out IDE drive... Kling3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2003 02:19 PM
Glyph Hot Swap Drive Error -- any help? tommydee Pro Tools TDM Systems (Mac) 3 02-06-2002 09:09 AM
