Old 03-11-2014, 07:17 AM
skjoeld skjoeld is offline
Default Re: Pro Tools Quicktime Server (Not Responding) 11.0.3 Mavericks
Originally Posted by dubbingmixer View Post
Just registered to get on this thread!
Just tried V11.1.2 and still cannot play video.
I'm seeing the same activity monitor message i.e. Pro Tools QT server not responding when I tried to bounce a video clip to QT to see if that would play.
The Avid Video Engine is loading, I've had no joy playing any video files, even files that did play in V10.
I'm using a mid2009 MBP with 8GB of memory and (damn) Mavericks installed, so border line spec I admit, but I did expect to be able to play back a 3 minute H264 file with a couple of audio tracks.
Has anyone got any work around for this?
Anyone found a fix for this?
Video isn't playing at all in Pro Tools 11.1.2 and Mavericks 10.9.2, and I get both
Pro Tools quicktime server not responding
and
Quicktime_OPserver not responding
in the Activity monitor.
Old 03-11-2014, 07:35 AM
P_J P_J is offline
It would be nice to get some expert comments about this. For me there's no problems with video, so those Activity monitor errors may not be the reason why you can't run video at all. Both MP and MBP rigs are having this same error in Activity Monitor. So clearly there is something wrong, even the video is working smoothly in my case.
QuickTime_OPServer (Not responding) x2
Pro Tools QuickTime Server (Not responding)
I'm using Photo JPEG for a video codec.
Old 03-11-2014, 01:49 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: Pro Tools QuickTime server RED ?????
Originally Posted by K Roche View Post
337 views and no replies ? Is no one else having this showing red thing going on ? There are about 6 so far over on GS. Kev.
Well then - at least one reply ... but won't help you as it is simply working here.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 03-11-2014, 02:02 PM
P_J P_J is offline
http://duc.avid.com/showthread.php?t=347731
Old 03-12-2014, 02:34 PM
I just did a clean install of the OS and Pro tools, and the
is now not occurring but Pro Tools will still not play video. Just black thumbnails on the track, and black video window. (QT, H264)
MBP mid 2009, OS X 10.0.2, 2,8 GHz Intel Core Duo, 8 GB 1067 MHz DDR3
  #16
Old 03-12-2014, 03:39 PM
clutch clutch is offline
The black thumbnails and video window sounds almost like it could be codec related.
I assume the video works well in other apps on the same rig?
When the PT QT server or QT_OP server stops responding, does it put any useful information into the Console logs? Is anything actually crashing and dumping a crash report to your ~/Library/Logs/CrashReporter/ directory? Posting the relevant crashed thread from one of those could help track things down...
He used to cut the grass...he was a very nice boy...
  #17
Old 03-12-2014, 06:46 PM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by P_J View Post
thanks for the link. I did a search but did not find that.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #18
Old 03-13-2014, 02:30 AM
Yes, I thought it might be codec related, but I have tried with videos with other codecs as well (and other movie files), and still no video playback in Pro Tools 11 on this MBP. (The video files are playing well in QuickTime Player and Pro Tools 10 on the same MBP, and also in Pro Tools 11 on other rigs that I have access to)
Since PT QT server or QT_OP server doesn't stop responding any longer I don't know if any crash report will be found, but I'll look into that anyway... Thanks for the reply!
  #19
Old 04-14-2014, 11:39 AM
audiofreak11 audiofreak11 is offline
Has anyone solved this?
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Intel iMac 3.4GHz i7 (late 2012) with 32GB RAM
Digi 003r
  #20
Old 08-14-2014, 11:04 AM
iamkimosabi iamkimosabi is offline
Default PT11 Force Quit Quicktime Server
I keep getting a (Not Responding) On ProTools Quicktime Server...I don't do any video on my PT11 sessions, how come this thing keeps starting up?
Anyone know how to fix this?
Thank you.
Pro Tools 10 for OS X Mavericks? datooch macOS 21 12-21-2017 12:54 PM
500 Internal Server Error We're sorry but the web server encountered an unexpected c DrumEatDrum Getting Started 10 07-09-2013 11:47 AM
Files transfered server-server relay still downloaded from remote server Phill Barrett Aspera DigiDelivery 1 03-19-2010 01:58 AM
ilok.com - server stopped responding. DaveSB Pro Tools TDM Systems (Mac) 8 12-08-2006 01:53 AM
