  #21
Old 04-18-2017, 09:57 PM
Default Re: vocal booth causing vocals to sound very boxy
Originally Posted by simon.a.billington View Post
I like the C6
Me too. It is one of the reasons I still tolerate Waves. Another reason is Dorrough meters, and the number three being L3LL-Multi. Without those three, I wouldn't have a reason to use their products.
  #22
Old 04-19-2017, 08:23 AM
gives's Avatar
gives gives is offline
Originally Posted by KingTor View Post
There are a lot of things I could think of to help. Unfortunately, the most significant one I can suggest would involve more cost and construction and that's to build a similar design but with two significant changes:
  1. bigger
  2. not square and with no 90° angles in the corners
  3. one more for extra credit: the floor and ceiling shouldn't be parallel.
If you're getting decent noise isolation but aren't happy with the "boxiness," I'm afraid that is the best approach for vocals. Parallel surfaces create reflections. We build some really quick-n-cheap booths for our second mix stage (and in the process made the corners of the mix stage better for mixing) by just drawing out some random, non-parallel walls with masking tape and telling a contractor to build walls on those lines. They were probably around 20 square feet inside, so a /little/ bigger than your 4x4 booth, but not a lot. I tuned them for commercial VO which is ideally recorded pretty (but not completely) dead, but they actually worked (much to my surprise) for ADR in a pinch, which usually demands a MUCH bigger space. (Still not as good as our current ADR stage which is about 120 square feet, and that's still considered small when clients ask for room dimensions--although they don't say it sounds small when they don't ask and only hear it. But I digress.)
If you're OK with recording totally "dead" vocals (i.e. with no natural room reverb at all), you could try some cheaper options first:
  1. the 4" thick foam option, mentioned by a few on this thread
  2. build bass traps for at least two of the corners
  3. use foam to create non-90° angles in the 4 corners
These are all good and correct ideas. Along the line of better wall quality treatments.
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2018.1 HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Sierra 10.12.6, Digital Performer 9.5
  #23
Old 04-20-2017, 10:00 AM
"boxy" usually means "walls" are too close to the source...
  #24
Old 04-20-2017, 10:31 AM
Southsidemusic's Avatar
Or wrongly built with cheap material that kills the tone too much.
Best Regards
Christopher
South Side Music Group
WEBHOME
SOUTHSIDEPUB
#ninjakittenshatecrunchyleaves
Eagles may soar, but weasels don't get sucked into jet engines
  #25
Old 04-20-2017, 03:29 PM
Marsdy Marsdy is offline
Originally Posted by chalz2502 View Post
dont know if im off topic but i need help understanding something. im pretty sure most engineers would know the answer to this. for the past 10 or 15 years i been teaching my self how to record vocals. almost every music gear i dreamed of having i invested over the years to get them. the only problem i ran into was not having a vocal booth to deaden the vocals. so a few months ago i went on this site called dawbox.com. its a site that offers blueprints of there designs to build a professional vocal booth. i bought the blue print and spent over a thousand dollars on material and labor to get it built. after it was built i was amazed how it turned out to look exactly the same as the creators said it would look. the only problem is once i went inside and gave it a sound test it didnt sound exactly how i expected it to sound. it isolated a bunch of noise from the outside and gave me a dead sound but it sounded muffled and boxy. im not sure if a professional vocal booth is suppose to sound like that. considering paying hundreds of dollars to get that thing built, i wasnt pleased and felt like if im gonna be sweeping away frequency out of vocals every time i record i shouldnt of wasted my money on this vocal booth. these people are very successful and i havent heard any bad reviews. the vocal booth i built is 4x4x7. i have accoutic foam in every single crack on the inside, i just dont understand. any professional engineers out there that know all the right answers to this type of situation please comment. help me understand the science a little bit more. what am i missing, and what dont i know that i thought i knew
Different dimensions but I have had similar problems. I'm assuming you're talking feet and not metres. There is no way a room that small is going to sound good. It sounds boxy because it's.... a box. You have equal room modes in two dimensions and the third dimension is close enough to 8 feet to create a mass of coincident room modes.
This could be your friend:
https://www.seelectronics.com/rf-space/
I've had far too many post-session cocktails to work out what your standing waves are but I wouldn't be surprised if you simply don't have enough space to put enough trapping in to get rid of any problems.
Sorry I can't be more positive but these booths are designed to cut out spill, not sound good.
Dave Marsden
UK
Avid HDX1, PT12 HD, HD I/O 16x16, Avid S6 M10 24-5, 2013 12 Core Mac Pro. Robby The Robot meter bridge ornament.
  #26
Old 04-20-2017, 04:01 PM
chalz2502 chalz2502 is offline
so your saying it'll be a waste of time to get the 4 inch foam?
  #27
Old 04-20-2017, 07:30 PM
Bookerv12 Bookerv12 is offline
Foam doesn't do what you are after.
It's OK for taming some high frequency flutter, but your problem would have to be attacked with a different material; Rockwool, Roxul, etc.
Foam is pretty much decorative.
bookerv12
  #28
Old 04-21-2017, 03:51 AM
edwinstar edwinstar is offline
yes, use rockwool!
Gesendet von iPhone mit Tapatalk
  #29
Old 04-22-2017, 08:00 AM
peterle peterle is offline
or even better as Rockwool is Basotect , with very interesting
capabilities , as seen here :
https://hofa-akustik.de/en/modules/measurements/
simple "foam" doesnt reduce the most problematic low-mid
and low frequencies in small rooms
foley artist , soundeditor
  #30
Old 04-22-2017, 10:51 AM
Default vocal booth causing vocals to sound very boxy
basotect for fullrange absorbing needs to be pretty thick and that's expensive! mineral wool is very effective when you use the right density (look for 60kg/m3 = 0.5lb/gal (US)) but needs to be covered with fabric.
Vocal Booth Mr.BossPlaya Tips & Tricks 4 07-04-2006 08:33 AM
How to build a sound proof vocal booth? CrAkD General Discussion 3 06-01-2005 12:59 PM
vocal booth sound evaluation--help? tokyofan General Discussion 3 02-24-2005 11:33 PM
boxy sound stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-28-2004 10:07 PM
Why do my mixes sound "boxy"? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 68 05-31-2001 11:19 PM
