Old 01-25-2019, 01:55 PM
Zep Dude Zep Dude is offline
Default Digidesign MIDI IO with PT 2018 / High Sierra?
Does anyone know if this is compatible in the current world? Drivers, Firmware etc? Last time I used it was many years ago with a much different (older) system.
Thanks
Angelo
Majestic Music
www.majesticmusic.com
Old 02-04-2019, 06:57 PM
685 685 is offline
Default Re: Digidesign MIDI IO with PT 2018 / High Sierra?
Yes, my unit works in 10.13.6
Zero problems at all when connected to the MacBookPro.
Weird hangup on the MacPro though. From a fresh startup Protools loads fine. If I were to close and reopen Protools, it will hang at the point it connects to the midi interface. If I hit the reset button on the Midi I/O's front panel Protools will then continue loading and the session will run without problems. Another fix is to leave the "Audio MIDI Setup" opened/running and no hang-ups will occur when starting Protools.
It's weird and I haven't figured it out just yet but I feel it have something to do with the Audio MIDI Setup. The same hangup issue happens with Logic. But again, no problems at all if I connect the Midi I/O to the MBP running 10.13.6
Command 8 work with high sierra and 2018.xx? analog orange ProControl, Control|24, Command|8 6 05-12-2019 05:41 PM
High Sierra + PT 2018.12 Ultimate issue Tyranor Pro Tools 2018 3 01-17-2019 10:25 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
PT HD 2018.1 HDX and High Sierra on Mac Pro Westmere 3,33 drums77 Pro Tools HDX & HD Native Systems (Mac) 5 02-24-2018 12:16 PM
High Sierra 10.13.3 PT 2018.1? off the wall macOS 10 02-16-2018 08:25 AM
