Old 07-19-2020, 11:11 AM
Soundworks UK Soundworks UK is offline
Default Re: Coreaudio problem Catalina
Originally Posted by musicman691 View Post
Have you tried holding down the 'n' key on your computer keyboard when starting PT? That will allow you to select your audio interface. PT hasn't had an uninstaller on a Mac in ages. There are steps to do a manual uninstall somewheres on the Avid site.
I’ve tried that, but thanks Jack.
Old 07-19-2020, 11:32 AM
Originally Posted by Soundworks UK View Post
Hi, thanks for the suggestions so far. The Apollo interfaces are working fine outside of pro tools and show up in audio midi setup and audio prefs. Ableton also sees Apollo via coreaudio , just not pro tools. The only available playback engine is Protools aggregate io. Not even built in output. I’ve already checked the mic access in security and it has it. There doesn’t seem to be a clean uninstalled for pro tools otherwise I would have tried that. I’m considering reinstalling the OS but would rather not if I don’t have to as EVERYTHING else is working fine. I tried plugging in some headphones but that didn’t help. I’ve uploaded a screenshot of the AM setup page. Appreciate your help so far, Simon.
Have you trashed Prefs? ... use Pete Gates PT Prefs utility and trash everything.
Old 07-19-2020, 02:24 PM
I trashed prefs with still no luck. So I did a system software restore. Still no luck. I’m totally out of ideas now
Simon Jones
Freelance sound creative. Bristol / Cardiff, UK
Re-recording mixer specialising in TV drama.
Mac Studio M2 Ultra 64gbRAM Focusrite Red16 line, Pro Tools Ultimate 2023.6
Old 07-19-2020, 03:13 PM
System restore how? Using the recovery partition and wiped everything? Then reinstalled all your apps? Or from TimeMachine? <- that's not a good test. Or something else?
I would have done a manual new install onto a spare container/partition using an installer downloaded from the Apple store. Not touched your current boot partition at all. I would use new downloaded app installers etc... extreme paranoia... you are just trying to prove it works at a baseline level (hardware might be faulty, there might be some deep bug a vendor needs to look at (and you have shown that with these tests on a clean system).
Actually I would do a full clean install of MacOS then install Pro Tools and confirm stuff works with headphones as the playback engine then try installing the UAD drivers. Just to KISS and be paranoid, even if I have no explanation for what is happening.
It is very hard to imagine how this happens, especially on a full new install. If you have tried that and done full reinstalls of Pro Tools and UAD software then who knows, it's time to contact UAD and/or Avid support. If things like headphones do not show up still as a Playback Engine option then the issue belongs to Avid and/or Apple, So start with Avid support. Posting your incident number here might help you get attention, or help others who run into this.
Old 11-10-2020, 02:32 AM
Thought I'd post an update on this as I found the culprit. I have a LG Ultrafine monitor that connects via Thunderbolt. I removed this monitor and now all is back to normal.
Simon Jones
Avid HDX CoreAudio on Catalina LukeHoward Pro Tools HDX & HD Native Systems (Mac) 11 05-08-2020 11:20 PM
Another CoreAudio Problem RecRoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-28-2008 10:08 AM
Coreaudio problem fawske3n 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2008 04:31 AM
Coreaudio Problem orange181 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2006 06:02 PM
CoreAudio 6.1.2 problem Michael Raco-Rands 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2004 11:19 PM
