Re: AAE-7058 error after I close and open PT again
Pretty nasty thing can you try removing all the plugins from the plugins folder and insert them again by brands ?
Some plugins licenses have the option to be on the cloud. Things can go wierd sometimes did you use the cloud before going out? Just asking looking clues here.
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Well since I have mixes to finish I could not wait for Avid or Apple or who "fault" it is to update the software.
I just opened TimeMachine and rolled the computer to a date 2 days before the error. I guess that if you have an iPhone with the new 13 iOS DO NOT plug it to the computer. Everything is working like a charm again! Getting back to mixes!
MacBook Pro M1 16G RAM OSX Big Sur 11.6 ProTools 2021.10 UA OCTO Thunderbolt, UAD Twin MK2 QUAD |
It's for when stuff like this happens that's it's not just a good thing but mandatory to have some kind of backup system in place. |
Yes i suspect that, but as he pointed an iphone conection ( not to do it ) it raise questions. So maybe a more deep info on what he suspect this would be good for all.
#16
Jesus - there are multiple threads about this on DUC, might be nice to combine them?
http://duc.avid.com/showthread.php?t=406401 (this one) http://duc.avid.com/showthread.php?t=406397 I thought there was one other, must have been confused, or maybe it was already merged? Folks opening cases - posting case numbers here would likely help. The Mac keeps a log of what has been installed in /var/log/install.log. I expect Avid support, iLok support and any plugin vendor support are likely going to want to see that. May be a good idea to attach that log file to support requests. I *think* Safari 13 may have been part of the update applied here, that could potentially touch a lot of underlying subsystems, libraries, etc. You never know in these situations, did Apple break something, did they fix something? Was some plugin toolkit vendor, Pace, or Avid relying on some improper or undocumented behavior etc. or did Apple just just screw the pooch? Finding the root cause may take several vendors looking at stuff together. Oh well folks who have backups and those who don't... maybe if you can't get stuff done because your Pro Tools system is having problems, now might be a good time to sort out doing backups. I'd go for using Carbon Copy Cloner for boot/system drive backups, a quick reboot off a clone can get you running again, possibly also backed up with TimeMachine, and possibly using TimeMachine for session backups in combination with cloud backups and off-site storage. Last edited by Darryl Ramm; 09-22-2019 at 01:07 PM. |
#17
I don't know if this has any relevance at all, but since the OP mentioned leving the mac alone for a while, coming back to discover the problem, I thought I would just point out that I have seen macs behaving strangely after logout/login or sleep and only a restart would fix it.
#18
hello to all.
i have the same problem with plugins apparently "not being authorized" after updating my iphone to iOS 13 (and mindlessly just installing the software update required for this operation). affected by this are my Sonnox Oxfords, McDSPs, NUGEN and my Empirical Labs Arousor plugs. what i found is that all of these plugins continue to work just fine in AU and VST format but not as AAXs in ProTools (2019.6.0). i noticed this while sending clips from my timeline to iZotope RX 7 Advanced via the RX 7 Connect AudioSuite plugin and opening the "unauthorized" plugs in RX 7's "Plugin" module. that (or a similar workflow of processing audio externally) might be a weak remedy for some affected users (i know, using e.g. offline loudness metering is not an effective workflow (i'm mixing tv stuff right now), nevertheless i wanted to share this). let's hope for the best. |
#19
To be clear
1. Turned the iMac off after a good session 2. Turned it on AND plugged my iPhone with the new iOS 3. A screen pumped asking to install something so the iPhone could work with the new iOS with the iMac 4. opened PT again and the plugins did not worked 5. After tried all things discussed before I ROLLED back to a day prior the problems. 6. All good now BUT wont plug my iphone before I finish all the mixes I have to work this week. Cheers!
#20
This is terrible, I can't roll back my clock, I get a iLok message saying "clock can't be repaired" also don't have TimeMachine This is bad |
Plugin Space (error AAE-7058) | mxPaulmx | AAX Plug-ins | 4 | 02-14-2018 09:21 AM |
DAE error -7058 | syMPh | Pro Tools TDM Systems (Mac) | 4 | 06-22-2010 03:18 PM |
Error "-4" and 7100+ 7058 with MDW EQ on HD system | groovebrother | Pro Tools TDM Systems (Mac) | 7 | 10-05-2007 10:27 AM |
DAE error 7058 with Amp Farm on new HD 2 Accel | belouder | Pro Tools TDM Systems (Win) | 3 | 01-31-2006 01:10 AM |
