Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-17-2018, 01:27 PM
rdpar's Avatar
rdpar rdpar is offline
Default No inserts???
hOW CAN YOU INSERT OUTBOARD GEAR IF THERE ARE NO "INSERT INPUTS" ON THE INTERFACE.??
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram
500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE)
Old 03-17-2018, 01:59 PM
BScout BScout is offline
Default Re: No inserts???
On i/o setup page, you assign your gear on the inserts tab. You will lose those inputs and matching outputs since they now belong to a hardware insert.
Old 03-17-2018, 04:19 PM
Drew Mazurek's Avatar
There are two separate issues here.
Do you mean inserting hardware while recording? For this, your interface has to have analog inserts that come after the mic pre but before the A/D.
Or do you mean using I/O on your interface as "hardware inserts" like BScout is referring to?
Also, what interface would be helpful to know.
www.drewmazurek.com
Old 03-18-2018, 06:37 AM
rdpar's Avatar
Yes while recording . I don't understand why most new interfaces do not have inserts. However I bought a Focusrite clarett octe pre, Which has an insert on each channel , but the 8 channel clarett interfaces don't. I really like using at least a compressor on bass and vocals going into my daw. So I guess , that must be old fashioned or something, to insert . Thanks for the info.
Old 03-18-2018, 10:22 AM
In many ways, "old-fashioned" is a fair term. Since you can(and should) record at 24 bit, which gives a lot of headroom, there is good reason to record at lower levels. So, recording with no inserted hardware compressor is reasonably safe from hitting overs. Having said that, many of us choose to use gentle compression on the way in and there are ways to do that without insert points if you choose your hardware right("right" being a relative term, not an absolute). In my own setup, the only preamps I have that actually have insert points is a Focusrite ISA-428(but I don't use them as they handle drum overheads, hat and ride channels). Where I do use inserts is between external mic preamps(which started as a simple pair in an API lunchbox) and those were done by simply chaining the preamp out>Compressor in>compressor out>interface in.
My best advice is to steer future purchases to products that allow you to do what you wish. One of the first things I recommend is 1 or 2 "money" channels for crucial tracks(vocals being top of the list) and a "money" channel is not likely to be any 8-channel box. Its much more likely to be a premium mic pre/compressor combo(and maybe with an EQ). As nice as the Clarrett boxes are, you would probably enjoy having maybe a nice Neve 1073 clone thru an LA2-A
Old 03-18-2018, 04:54 PM
rdpar's Avatar
So let me get this straight. I can take a direct out of my interface(which does not have inserts) , into my comp. out of the comp. into a line in on the interface? Yes , wouldn't we all love to have a couple "money pres".:):)
Old 03-18-2018, 06:40 PM
Depending on the interface, that could work dandy. "Money" channels can actually be done on a modest budget, and in stages. If you have good soldering skills, it gets even cheaper. There are a few companies that sell kits for excellent preamps(CAPI and Five Fish Audio both make great API 312 preamps in kit form). Buy a pair of kits for a great start. Follow that up with a pair of decent compressors(Warm Audio WA2A or build a pair of Hairball Audio 1176's). The Vintech 273 is another great option(at a higher price point) that includes enough EQ for any tracking(many of us track flat anyway). Even though I have outboard EQ's available, I rarely use them(plugins can match most any)
Mbox Pro "Inserts" vs "Hardware inserts" GoGoJoe FireWire & USB Audio Interfaces (Win) 30 01-21-2016 03:39 PM
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
m box inserts ez dollaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-31-2005 08:09 PM
anyone know where to get low run cd inserts? superpenguin79 General Discussion 5 11-08-2005 10:09 PM
inserts on 002 vicwind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-02-2004 07:42 AM
