operating system held off, warning -6089
I can not get any play back in my session, when I hit space bar it just freezes and come up with this warning. "The operating system held off, interrupts for too long. If this occurs frequently try increasing your HW buffer size in your playback engine panel (-6089) I have try doing this and still noting will work. Do any of you know what else this could be? I am running quite a large session!
Thanks |
Re: operating system held off, warning -6089
have you tried changing the DAE settings? i had problems bouncing once and that did the trick. are your hard drives DMA enabled? did you do a search on this topic in the forum?
Jeremy Forbis |
Hi!
System info, Digi hardware, etc. please.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
This happens me all the time, even when i only have one or two tracks. i have a very fast dell laptop and a digi002R. i've tried everything that has been suggested on this forum and it still happens... if anyone knows anything about this please let us know. i have a friend who has the same problem with an mbox
Which Dell? 8500 or 8600? What's your buffer size set to?
Rail
inspiron 5150
3.06 ghz pentium 4 512 mb ram this happens even when the buffer is set to 1024 |
Can you list your IRQ assignments as found in Device manager?
Rail
I dont have a clue how to do that, i'm not very computer litterate... i looked in the device manager and couldn't find any irq lists. where would they be
Rail
i think i found it...
(ISA) 0 System Timer (ISA) 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard (ISA) 2 System Board (ISA) 8 System CMOS/real time clock (ISA) 9 Microsoft ACPI-Complient System (ISA) 12 Synaptics PS/2 Port Pointing Device (ISA) 13 Numeric data processor (ISA) 14 Primary IDE Channel (ISA) 15 Secondary IDE Channel (PCI) 5 Broadcom 440x 10/100 Integrated Controller (PCI) 5 Conexant D480 MDC V.9x Modem (PCI) 5 SigmaTel C-Major Audio (PCI) 11 Intel 82801DB/DBM USB 2.0 Enhanced Host Controller - 24CD (PCI) 11 Intel 82801DB/DBM USB Universal Host Controller -24C2 (PCI) 11 Intel 82801DB/DBM USB Universal Host Controller -24C4 (PCI) 11 Intel 82801DB/DBM USB Universal Host Controller -24C7 (PCI) 11 NVIDIO GeForce FX Go5200 (PCI) 11 Texas Instruments OHCI Complient IEEE 1394 Host Controller (PCI) 11 Texas Instruments PCI-4510 Cardbus Controller Thats it. Thanks |
The operating system held off interrupts for too | DepecheNYC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-14-2007 07:17 PM |
The operating system held off interrupts for too | JacobIz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-11-2007 07:42 AM |
"Operating system held off..." error | grasshopper47 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-07-2005 10:56 AM |
OPERATING SYSTEM HELD OFF INTERUPTS???!?? | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-28-2001 01:30 PM |
What is "operating system held off to many interrupts" | WestPhillySoulzition | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-16-2001 12:43 AM |
