Old 07-15-2005, 05:11 PM
gjohung gjohung is offline
Default VS880 to ProTools
I have many project that I did it on Roalnd VS-880. I want to somehow convert that into PT files. VS-880 can "play" only 2 channels at a time, but VS 880 is an 8 track Digital Recorder. Is there a way to record 2 tracks at a time and somehow synch all tracks.
Furthernore,, I have stacks of old Fostex A-8 Tapes Analog tapes. I found someone who has the Machine collecting dust. I have M-Box - record at 2 track at a time. Or... a M-Audio Quattro.. 4 track at time... but this A-8 tape has full 8 tracks.. ...how can I synch this..
ghj
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB
ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49
Old 07-15-2005, 05:54 PM
gonzo99 gonzo99 is offline
Default Re: VS880 to ProTools
I have moved projects from VS880 to ProTools in the past.This may not be the easiest way but what I did:
for projects where all I wanted was a stereo mix: record left and right master outs to a stereo channel in PT.
Where I was wanting the individual tracks: record each track - 1 at a time or one panned hard left and the other panned hard right - to a mono tack in PT. Then move the audio in the edit window to synch the tracks.
Like I say, not the easiest or fastest way, but it works.
Hope this helps
gonzo
HANSON'S RAZOR:
Never attribute to evil that which can be adequately explained by stupidity.
Old 07-15-2005, 08:30 PM
omoanya omoanya is offline
I am so happy you guys raised this issue, though I was really hoping someone already pulled off a digital transfer from 880 to 002rack, time code and all . I'd really like to keep using my 880 remotely and use it to ferry tracks to the home studio, instead of buying a mac laptop which i cant really afford ..does 880 record to aiff? maybe thats a route to pursue? . Anyone else?
Old 07-16-2005, 12:42 AM
It's a tuffy, but I was thinking if you can use the MTC to sync it. I actually tried this. Sequenced the backing tracks on Sonar and just mixed on to VS880 analog line out to 2 track. I took the VS880 with 6 tracks remaining and recorded live vocals etc. Brought it back and resync it.
However, there was a tremodous degradation of audio quality. after all it is a A-D-D-A back to A-D process. I wanted to use SPIF but my audio interface does not have one, M-Box and M-Audio Quattro,
if I use SCSI or even mix to a zip drive, can it be read on mac/pc as a audio file??
ghj
doesnt oo2 have spdif??? u can do D to D recording...
Old 07-16-2005, 07:39 AM
Transceover Transceover is offline
yes I was hoping to hear someone had already done the digital transfer as well... I have a ton of material I want to transfer in to protools and I had everything set up to do it digitally (via spdif) but I could not get anything to synch w/ time code etc... Ive thought about doing things the slower way of recording one track at a time (I have actually done a few things this way with much success) but was hoping someone here had done it differently...
any thoughts from anyone else here? perhaps check the 880 boards too... I havent yet.
THANKS!
K.elly
K. Cornelius
Musician/Artist
Transceover Productions
[email protected]
Old 07-16-2005, 02:32 PM
s.d. finley s.d. finley is offline
I have transfered a buddys 2480 sessions into PTLE. He has a cd burner, so i had him consolidate all his tracks from top to bottom, and burn those as .wav files on a data cd. Works great!!! Also had a client the other day where we transfered tracks off his akai dps16 HD recorder via MTC. The akai is a 16 track recorder. I skipped the stock AD on my 001, and went thru a dbx and a DA7. Also, worked great!!!
rock
sdf
sdf
www.sugarhillstudios713.com
Old 07-16-2005, 09:32 PM
One issue with sound quality in the Roland stuff has nothing to do with A-D/D-A conversion.
I have been told that the VSx80 units save audio in a proprietary lossy compression format similar to MP3, which is why everything done on them ends up sounding overcompressed and kind of dead. I know I would always wonder how things ended up sounding so flat and lifeless even though everything sounded good thru monitors/headphones when tracking. Apparently this is why. Anyone know more about this?
Also, for transfer via cd-r burn found this post in the PTLE for PC forum.
gonzo
HANSON'S RAZOR:
Old 07-17-2005, 01:25 AM
jnash jnash is offline
Been a long time since I've done this, but I remember transferring some tracks from a VS880 to PTLE/001. I sent out two tracks at a time via S/PDIF and used MTC to sync the two devices together. It IS possible. I think I remember that I couldn't get the VS880 to slave to ProTools, but ProTools was able to slave to the VS880... then again, it's possible I'm remembering that wrong--if one method doesn't work, try the other. Also, you'll probably need to play around with the clock offset in ProTools--I think I recall a discrepancy in song positioning. Also, keep in mind that MTC is FAR from sample-accurate... if you really want the tracks to line up perfectly, you might want to record a spike of some kind on all tracks of the VS880, then adjust the precise track locations by eye in ProTools. I still found it useful to have MTC get everything close, though.
Sorry I can't give you step-by-step instructions. I got rid of my VS880 several years ago.
Good luck!
James
[email protected]
Old 07-20-2005, 02:56 AM
is there a way to back up 880 data on to CD or Zip, and then retrieve it as wav into PC or Mac. I have heard some one did that..
.012 -second gap when recording from VS880-EX John Link General Discussion 1 05-08-2005 09:25 PM
using effects from vs880 MPB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-05-2003 08:47 AM
Roland Vs880 ThatHitSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2003 11:00 AM
vs880 as HUI controller? Jaleo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-26-2001 09:32 AM
PT Sync with VS880 walter Pro Tools TDM Systems (Mac) 0 10-05-2000 02:53 PM
