Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 10-07-2020, 06:10 AM
TornadoTed TornadoTed is offline
Default Can someone please explain Ableton Link
Can you sync Ableton Live and Pro Tools via Ableton link running on the same computer? I know it can be done using ReWire but only with a 'light' version of Ableton with lots of features disabled.
Every mention I have seen says that it can sync with another Ableton Link device as long as they are connected to the same LAN, no mention of the same computer.
I currently sequence my MIDI hardware with Pro Tools and use it as a live digital mixer monitoring all my hardware synths where I can mix, add effects and process etc. I would be interested in moving the MIDI sequencing side to Ableton. How would it work with setting up the audio interface, MIDI interface etc. Can 2 DAW's share devices?
Old 10-07-2020, 07:01 AM
Marsdy Marsdy is offline
Default Re: Can someone please explain Ableton Link
Yes Link works with both DAWs running on the same computer. Just enable Link in both PT and Live. It depends what you want to do though because it’s not the same as syncing using MTC.
Linking MIDI between DAWs can be done with IAC on a Mac. I’m connecting Live or Logic audio to pro tools via hardware. I have a Focusrite Rednet PCIe card piping audio via Dante into an Avid MTRX Studio via Dante.
Dave Marsden
UK
Old 10-07-2020, 07:55 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Using two apps on the same computer means they are inherently on the same network. I have only tried it with iMachine 2 on the iPhone with the MacBook. It certainly played back in sync AOK so I am sure those on the same PC will be good too?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 11-17-2020, 03:59 PM
ratava911 ratava911 is offline
I know this used to be (or perhaps still is) using rewire to route ableton into pro tools.. .How is it done with ableton link? I've tried changing the output for tracks in ableton but I can't figure out how to get them to connect in protools
Is rewire still needed??? If not, how do you route ableton tracks to audio/instrument tracks from ableton to protools??
Old 11-17-2020, 05:59 PM
Sardi Sardi is offline
Link only provides tempo sync. It does not pass audio.
ReWire has been deprecated so there won’t be support for it moving forward.
Old 11-17-2020, 06:01 PM
oh wow.. that sucks. I guess I'll see if re-wire works in 2020.
Old 11-17-2020, 06:04 PM
If the goal is to pipe audio from Live to PT, you might need to use Ableton Link for the sync and then use something like Loopback to route the audio back into PT.
Old 11-17-2020, 06:14 PM
Ben Jenssen's Avatar
That is mac only. Core audio on mac.
Old 11-17-2020, 06:54 PM
Could someone give me the steps to do this... Sorry. This is documented absolutely nowhere! I have been googling for hours!!!
Old 11-18-2020, 12:50 AM
It is and the poster in question lists Mac OS in his system specs.
Looking for cool applications of Ableton Link ejinbc Pro Tools 2020 1 09-13-2020 07:17 PM
Ableton Link... Why So Cryptic? grayter1 Pro Tools 2020 9 09-06-2020 03:03 PM
PT 12 & Ableton (routing PT 12 into Ableton for using Sends) Feinbeat Getting Started 1 02-23-2017 10:31 PM
PT HD CORE & HD ACCEL + SSL Delta Link + SSL Alpha Link Noizz focushocuspocus Pro Tools TDM Systems (Mac) 1 09-29-2012 08:12 PM
Pro Tools Playback Issues at 88.2 with Delta Link / Alpha Link - Any ideas? azirkin macOS 1 01-17-2012 01:30 AM
