Re: Pro Tools Bugs out the Kazoo
But any way. I have been able to educate myself on what not to do and what to do enough to have about an 80% successful stability rate now, which is "ok". My biggest disappointment is that I compose full orchestra tracks. 32 PT Tracks even as Instruments is quite... inadequate. |
I guess I just look at it like this. If I (and lots of other users) can run PT on my system with the kinda things I ask it to do, which is often a lot, and not have any problems, it just makes me think that its something with your computer, hardware, or the 3rd party softs that you use. Its a flat out fact that the PT software is the same from studio to studio, in relevant class (LE, MP, HD). So, if all the software runs the same, and lots of people don't have problems, but you are, then its something specific to your setup. Just trying to implement some deductive logic here. If you want to get rid of problems then spend some quality time going through all the optimization and troubleshooting. Make sure all your computer and recording hardware is supported and up to date. Make sure all your softs are supported. And make sure your not using any Digi "no no's".
www.TheSoundCoop.com www.youtube.com/TheSoundCoop PCAudioLabs 2.5GHz Quad-Core Q8300 FSB:1333/1066MHz, NB:IntelG33, SB:Intel ICH9DH/WinXP Pro SP3 / SATA HD's = 160GB(7200/8), 320GB (7200/16) x 2,500GB (7200/32) / 4GB DDR2-800 / FW = TI ChipSet / Gear: Apogee Rosetta800, ADL600, Avalon2022 // M-Audio = Profire Lightbridge, Octane 8's, BX5's BX8's & SBX // ProTools MP 8.0.5 w/ MPTK 2 - Velvet Waves Sonnox IK NI FXpansion Massy -- DVerb2.0 Test = 230 verbs |
Well, is that really valid deductive reasoning? It works for you...therefore...
?? No, not to discourage advice/help but it really isn't. It's "likely" a combination of new PT8 introduction (coding - with the likeliness of mediocre to nearly non-exisiting testing enviro - inhouse at digi or outsourced. Welcome to digi testing - you're it!) and also very likely a services/processes, driver/os/sys setup (on the user end). It's likely a combo of both in this case by his description. I know PT8 has some hurdles of it's own to work through. This is exacerbated when we talk about digi and the windows enviro as well. And, it's not just Digi that suffers from this of course, ....but if we talk about tiers of stabilty, I'd place PT8 somewhere near mid-bottom ("features" , and stability). No need for a full sandra report. Facher, is this by chance a storebought, off the shelf/namebrand system? What services are running upon bootup? (type ctrl-alt-del, read and list processes or make a screenshot .jpg of it. ). What is checked in startup tab of msconfig? (go: start - run - type "msconfig"). list all that are checked. Resolve might be as simple as managing some services - (start - run - type "services.msc") * Personally, I never, ever...ever buy a system off the shelf. I will always research the parts and build myself based on the needs. And no Vista. There's no need for it. If Vista must be purchased, then you contact MS explain the details/issues and demand XP downgrade. I've done it several times now for customers. |
However, the problems that Facher is having are not bug related issues. They are problems that are occurring from 3rd party software , recording hardware or computer hardware issues. How do I know... cause I had lots of problems when I first started using ProTools on Windows with a crappy Dell computer. I had to optimize everything. I had to make sure I had supported chip sets for my Firewire. I spent several weeks going through everything making sure it worked just right. And for a long time I didn't have any problems minus the fact that my computer wasn't powerful enough for the stuff I was doing. It is a pain that we have to do this to make ProTools run. I agree to that, but here is my biggest point... I upgraded. I got a PCAudioLabs and this thing is smoking. Its faster then I need. Its completely optimized right out of the box. I plugged this thing is and didn't have to set a thing, aside from my hardware I/O. Right out of the box this thing has worked flawlessly. Never had one PT crash or other problem that wasn't related to a bug that needed fixing by Digi. Therefor it is sound deductive logic to say that ProTools (minus the bugs) runs fine. Its the computer hardware, recording hardware and 3rd party softwares that gets us into trouble. And its safe to say, that seems to be what Facher is experiencing.
As far as 3rd party items, I'll say that PT had issues getting started out right, before running Reason at all or anything else. |
#16
This is just an observation, so don't get pissed, but the fact that you do gaming, office work and stuff like that on a machine that works PT is probably not the best place to start. If your gonna work audio, you might want to get yourself an exclusive system. Its not a matter of life and death, but as important as it is to me to have a system that functions very very well, i would never consider installing anything that wasn't related to audio, or troubleshooting audio/hardware probolems. Just my 2 cents right off the bat. This also means no internet access of any kind, definalty no wireless of any kind, along with a few others.
This kinda goes back to a few things. It might have had to do with hardware problems. Either on your computer, or as a part of your recording setup. Or, and this is more likley since your doing all kinds of stuff on your PT computer, maybe it was the fact that you never optimized your computer. The fact that you're just getting around to setting up a Clean Windows Dual Boot does suggest that was never done in the first place. On Windows, optimization is not an option, its a must, if you don't want problems. And yes I do think its lame, but its still necessary.
#17
For those of us who can only afford one 'good desktop machine' at any given time, we also need them for: web development, email, online banking, networking, communication, etc. Not everyone can run in their 'ideal' environment. If I were to have my way (by having loads of cash) I'd simply hire an orchestra and recording studio to make the music - but that isn't going ot happen right now. Quote:
#18
Believe me, I understand your situation man. I really do. I didn't always make money ProTooling, and I didn't always have money to spend. Never been rich, or had money on trees out back. And really it has little to do with that. This is not about your need to invest more money, but rather more time taking care for essentials. Based on your very first post on this Thread it came across like were pissed that you spent all this money, and it didn't work. Just because you spend money to get the recording gear doesn't mean you are good to go, or even know what your doing. Believe me, I've been there. If you want smooth operation, its YOUR job to make sure all your hardware is supported, and all the optimizations have been done. Hindsight it sounds to me like your problems are due to a laq of windows optimization. If thats not the case then its your computer hardware, NOT your ProTools MP software. Quote:
#19
So, point and clicking in the score window... you can drag to the right to extend a note's written length... however, at some point, accidentally moving the mouse up (or something), hard crash, Pro Tools 8 window goes *poof* into thin air.
Woohoo. |
#20
Doesn't seem to be workng for them there either.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
Pro tools 11 Bugs | YKlein | Pro Tools 11 | 3 | 10-17-2013 08:36 AM |
Unintelligible kazoo sound when listening | vinnieuk | Windows | 25 | 10-03-2013 09:59 PM |
Bugs in Pro Tools 9.0.3 | mkosacek | Windows | 3 | 06-30-2011 03:43 AM |
Pro Tools LE 7.0 Bugs | Larry Younkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2005 11:55 AM |
