  #41
Old 02-07-2010, 02:52 AM
fridrikur fridrikur is offline
Default Re: Update 8.03 causes problems running win7
Originally Posted by TOM@METRO View Post
I'm a little confused; looking at you Sandra report makes me wonder why you have chosen a 64-bit Operating System when you have so little CPU power and RAM. A 64 bit OS only comes to life when RAM exceeds 4GB and CPU resources plentiful
I agree but I am also going to upgrade to 8gb of ram very soon, so this was part of the plan. But I cannot see why core 2 duo processors should be considered as little cpu power?
Intel(R) Core(TM)2 CPU 6400 @
2.13GHz
Intel Corporation DQ965GF
Memory: 2GB
ST3250310SV 250GB (SATA300, 3.:233GB (H:)
ST3320620AS 320GB (SATA150, 3.:298GB (C:)
External Harddisk: Lacie D2 Quadra 1 TB firewire 400 (Oxford 11 chipset - using a different firewire card than fw410)
Windows System: Microsoft Windows 7 64 bit ultimate
M-audio Firewire 410 (ADS PYRO PCI 64 bit firewire card with Texas instrument chipset)
(6.0.1_5.10.0.5058)
Pro Tools M-powered 8.03
  #42
Old 02-07-2010, 04:44 AM
Talking Re: Update 8.03 causes problems running win7
I checked the registration database (regedit) for 'errorReport.dll' and found numerous incidents of this file all residing in software folders from Sony. I then found that file in the Program files/sony/ folder and checked that the file has a digital signature from Sony. But I figured it could not hurt to copy that file over to the Digidesign/ProTools folder.
And wouldn't you know! It fixed the annoying error!
So no more annoying pop up windows saying: 'errorReport.dll is missing'.
Why Pro Tools would need one of these files is beyond me though.
I do use plugins from Sony but they are all VST based, so they should not interfere with the plugins in ProTools? I also deleted all plugins testing the PT8 system. Now I am going to see if I can install the 3dparty plugins from IkMultimedia, and Overloud and sofort.
2.13GHz
Memory: 2GB
(6.0.1_5.10.0.5058)
  #43
Old 10-19-2010, 01:16 PM
tech2000 tech2000 is offline
Thumbs up Re: Update 8.03 causes problems running win7
I had the same problem and i reformatted and reinstalled win 7 (32 bit)
and reinstalled PT 8,8.01,8.04 in succesion and still had the problem
and continued to use PT 8.04 with the error anyways
""""erroreporting.dll can not be found in your system""""""
until..........drumroll please....
I tried to bounce to disk a composition I had made to MP3....no go....
and I remembered I had purchased the MP3 option from Digi
reinstalled it from the PT8 installation CD/DVD and i restarted
Protools and Voila!!!!! no error.
I think this error is generated by the Ilock dongle, because as soon as it saw
the mp3 option and authorized it ,the problem went away
Hope this helps somebody
Problems Running Pro Tools 11 (Win7 64-bit) FactionsOfArt Windows 21 12-06-2013 09:17 PM
HD9.0.5 win7- carefull with amplitube 3.0.7 update is a BIG no no grendizer Pro Tools TDM Systems (Win) 1 11-17-2011 04:24 AM
Im running PT8 on WIN7(running off of VMWARE) Conolly10 Windows 2 12-11-2010 06:38 PM
PT8 Win7 problems St.BeesJevans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2009 12:50 PM
When is Avid going to update the Win7 compatibility announment ? adelestevens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-26-2009 05:47 AM
