Old 12-28-2013, 01:01 PM
2224 2224 is offline
Default CoreAudio with HDX
I am running a 8 core Mac with OS 10.8.5 and HDX card with 16x16 interface, I would like to use Logic 10 sending the inputs and out through the interface but have not been successful so far, can any one help with this??
Thanks
JAMAICAN I IS
2008 2009 and 2010 Mac Pro 8 core with
64 GIG memory with 9 terabyte of hard drive space
blue ray player
HDX 1, 2 16X16 interfaces
sync I/O.
Old 12-29-2013, 07:19 AM
Drew Mazurek's Avatar
Default Re: CoreAudio with HDX
Thanks
Did you install the HD Driver?
http://avid.force.com/pkb/articles/e...nload/en379411
www.drewmazurek.com
Old 12-29-2013, 09:18 AM
Originally Posted by Drew Mazurek View Post
I un installed and re installed the driver 5 times before posting, made no difference, I still don't get the option to use the HDX card just aggregate.
JAMAICAN I IS
blue ray player
sync I/O.
Old 12-29-2013, 10:42 PM
Rob Da Silva's Avatar
Rob Da Silva Rob Da Silva is offline
Make sure the 16x16 is on.
Launch the CAM manually.
Applications>Utilities>Avid CoreAudio Manager.
You should get the CAM status box saying connected.
Change the sample rate if necessary from the HW Setup box. Click OK.
Go back to the status box.
Then Click Prefs.
Uncheck "Auto quit manager when last client quits" box. Click OK.
Launch Logic Pro.
Let me know if this does it or not. It's been working for me about a year now.
File Type: png Screen Shot 2013-12-29 at 9.45.29 PM.png (68.9 KB, 0 views)
File Type: png Screen Shot 2013-12-29 at 9.45.56 PM.png (39.0 KB, 0 views)
Rob Da Silva
Owner/Producer/Engineer PurpleCatAudio LLC
MAC Pro Intel 2x2.4 Quad-core Xeon 24GB OSX Lion 10.7.5 HDX 16x16 I/O PT11.0.1 C24 Control Surface
Old 12-30-2013, 01:18 AM
Then Click Prefs.
Launch Logic Pro.
I just want to say thank you very much Mr Rob Da Silva for this, I did what you said and it's working, now I have a few more questions if you don't mind, do I have to do this every time I open Logic and leave the CAM open for Logic all the time, and can I use 2 16x16 with this setup??
Thanks again
JAMAICAN I IS
blue ray player
sync I/O.
Old 12-30-2013, 06:25 AM
Thanks again
Glad to help 2244.
Logic should launch the CAM on its own once you get the Prefs set to not have the app auto quit. Protools always initializes hardware on launch so it gets confusing depending on where you start.
Safest to use this technique when running Logic as the first app attached to the CAM.
Once the CAM is running, it will remain running until the the computer is shut down. It should be seen in the dock. You can also quit it manually in the status box. And as long as the 2 16Xs are daisy chained to the HDX card, you should be fine.
If you want to see this, uncheck "Hide manager if auto-launched by client" in the Prefs.
Rob Da Silva
Old 12-31-2013, 12:51 AM
Glad to help 2244.
Ok, and thanks again
JAMAICAN I IS
blue ray player
sync I/O.
Old 01-01-2014, 11:07 AM
TCLguy1 TCLguy1 is offline
This is very interesting. I am currently using Logic and HD on 2 separate machines. I am considering going to HDX and using PT for some tasks like mixing and Logic for other tasks (but all on one computer). My question has been how many in and outputs can I use in Logic with HDX. I believe I heard 32 in / out is the limit (which is fine for my Logic side of things). Is that correct?
Best,
TCLguy
_________________________________________
12-Core Xeon 3.33, Antelope Audio Goliath, Logic, Live, PT12HD
Dual 2.7 G5, ProTools HD3, 2*192's, SSL Delta Link
iMac 3.0 , Abelton live
MacBook Pro, Logic X for Video
Old 01-01-2014, 11:13 AM
JFreak's Avatar
JFreak JFreak is offline
I believe HDN/HDX can use 64 i/o using CoreAudio. Huge improvement compared to 8 i/o of TDM systems.
Janne
Old 01-01-2014, 11:34 AM
That would be fantastic! Anybody using it that way?
Best,
TCLguy
CoreAudio & PT8 orpheus_2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2009 01:07 PM
CoreAudio 6.9 with 001 PT 6.4??? macaholic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2006 03:37 PM
Possible Bug with CoreAudio 6.7?? Anyone else? O.G. Killa Pro Tools TDM Systems (Mac) 4 12-03-2004 09:17 PM
CoreAudio... What is it? SimpleNatureSpirit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-10-2004 05:23 PM
001 & CoreAudio ronstephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-01-2003 09:14 PM
