Old 07-09-2011, 11:48 PM
45revolutions 45revolutions is offline
Unhappy Firmware upgrade failure
New issue
An unexpected error occurred while transmitting firmware image. Error found while verifying the write was done correctly. (-1167)
This is on the launch of 9.0.4
Old 07-10-2011, 01:52 AM
midnightrambler midnightrambler is offline
Default Re: Firmware upgrade failure
You've done it the wrong way round, you've installed the OS first. I made the same mistake and got the same error. The only way I found to get round it was to re-install an earlier OS (in my case 10.5.4), and then launch 9.0.4, Total ball ache, but I did get it working. Good luck.
Mbox 2 Mini not responding after firmware update failure creeperdet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-13-2011 01:13 PM
003 rack firmware update failure.. sguy006 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-29-2009 10:09 AM
Firmware update failure raphael.chevalier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-18-2009 02:10 AM
PT LE 6.4 002 Firmware Download Failure chucksil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-26-2004 07:29 PM
